Lets encrypt self signed certificate auto-renewal or not
My domain is: No domain(Its self signed cert)
k get certificate
NAME READY SECRET AGE
letsencrypt-ca True letsencrypt-ca 43m
apiVersion: cert-manager.io/v1
kind: ClusterIssuer
metadata:
spec:
  selfSigned: {}
kind: Issuer
metadata:
  namespace: sandbox
spec:
  ca:
    secretName: letsencrypt-ca
kind: Certificate
metadata:
  namespace: sandbox
spec:
  isCA: true
  commonName: osm-system
  issuerRef:
    kind: ClusterIssuer
    group: cert-manager.io
It produced this output: It has created a certificate, my Question is that its a self signed certificate we have generated to use it across some services IP addresses.Can it act as a self renewal certificate in future?
Please confirm. Thanks.
If you're using a self-signed cert, then you aren't using a cert from Let's Encrypt. You're also not using software from Let's Encrypt.
No idea; you haven't even specified what software you're using to try to get whatever cert you got, though the section you posted (of whatever it was) suggests you're using cert-manager, which would in turn suggest you're using Traefik. You'd likely find more help in whatever support channels exist for Traefik and/or cert-manager.
Some suggestions:
