My domain is:w3resource.com
I ran this command:certbot renew --dry-run
Processing /etc/letsencrypt/renewal/w3resource.com.conf
tls-sni-01 challenge for w3resource.com
tls-sni-01 challenge for www.w3resource.com
Waiting for verification…
Attempting to renew cert (w3resource.com) from /etc/letsencrypt/renewal/w3resource.com.conf produced an unexpected error: Failed authorization procedure. www.w3resource.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested d8cd479ecd522dcd15a8945140ae2add.c56da03b53295f0632e5c9ef5279371f.acme.invalid from [2400:cb00:2048:1::6819:6210]:443. Received 3 certificate(s), first certificate had names “*.3ho.org, *.alluremedia.net.au, *.cappitech.com, *.digitalempire.io, *.hardrock.gl, *.ikyta.org, *.imprensafalsa.com, *.l2i.ru, *.vanityisland.it, .w3resource.com, 3ho.org, alluremedia.net.au, cappitech.com, digitalempire.io, hardrock.gl, ikyta.org, imprensafalsa.com, l2i.ru, ssl378181.cloudflaressl.com, vanityisland.it, w3resource.com", w3resource.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 6aa6cb1b2638330f3e5050cb337cad90.d9c3c2bed8a2e6617743d43c76896dd6.acme.invalid from [2400:cb00:2048:1::6819:6310]:443. Received 3 certificate(s), first certificate had names ".3ho.org, *.alluremedia.net.au, *.cappitech.com, *.digitalempire.io, *.hardrock.gl, *.ikyta.org, *.imprensafalsa.com, *.l2i.ru, *.vanityisland.it, *.w3resource.com, 3ho.org, alluremedia.net.au, cappitech.com, digitalempire.io, hardrock.gl, ikyta.org, imprensafalsa.com, l2i.ru, ssl378181.cloudflaressl.com, vanityisland.it, w3resource.com”. Skipping.
/etc/letsencrypt/live/w3resource.com/fullchain.pem (failure)
Domain: www.w3resource.com
Detail: Incorrect validation certificate for tls-sni-01 challenge.
Requested
ssl378181.cloudflaressl.com, vanityisland.it, w3resource.com”Domain: w3resource.com
Requested
ssl378181.cloudflaressl.com, vanityisland.it, w3resource.com”To fix these errors, please make sure that your domain name was
My web server is (include version): Apache 2
The operating system my web server runs on is (include version): Ubuntu 16.04 64 bit
My hosting provider, if applicable, is: Digital Ocean
My renewal file in /etc/letsencrypt/renewal/w3resource.com.conf looks like following :
renew_before_expiry = 30 days
version = 0.17.0
archive_dir = /etc/letsencrypt/archive/w3resource.com
cert = /etc/letsencrypt/live/w3resource.com/cert.pem
privkey = /etc/letsencrypt/live/w3resource.com/privkey.pem
chain = /etc/letsencrypt/live/w3resource.com/chain.pem
fullchain = /etc/letsencrypt/live/w3resource.com/fullchain.pem
[renewalparams]
authenticator = apache
installer = apache
account = ff1d8862d4522d39651cb9e3813dedf2
I have also configured a cron task :
00 8 * * * /usr/bin/certbot renew --quiet
My site is running on HTTPS now. I am using Cloudfare also. Any suggestion to fix the renewal issue would be appreciated.
