Lets Encrypt & Port 80 Issues
My domain is: honkymedia.shop
I ran this command: N/A
Domain: honkymedia.shop
Type: connection
Detail: Fetching
http://honkymedia.shop/.well-known/acme-challenge/9F15fZCQJRYqsSorsGAPne7K2pmnJBkYtxtOlZ3d-f4:
Connection refused
ERROR: Cert does not exist! Please see the validation error above. The issue may be due to incorrect dns or port forwarding settings. Please fix your settings and recreate the container
My web server is (include version): Unraid 6.7.0
The operating system my web server runs on is (include version): Unraid 6.7.0
My hosting provider, if applicable, is: Namecheap
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): No? Namecheap and duckdns
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): linuxserver/letsencrypt
I have had this running fine for the last year. Yesterday I installed lidarr docker, changed the lidar.subdomain.conf.sample to remove ".sample", and updated all my dockers. Everything worked, I believe, until I did the update. So, I wiped it clean and started fresh, but I am still receiving errors that LetsEncrypt cannot talk to my domain name.
Letsdebug.net:
ANotWorking
ERROR
honkymedia.shop has an A (IPv4) record (185.198.126.26) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
Get http://honkymedia.shop/.well-known/acme-challenge/letsdebug-test: dial tcp 185.198.126.26:80: connect: connection refused
Trace:
@0ms: Making a request to http://honkymedia.shop/.well-known/acme-challenge/letsdebug-test (using initial IP 185.198.126.26)
@0ms: Dialing 185.198.126.26
@147ms: Experienced error: dial tcp 185.198.126.26:80: connect: connection refused
Docker Setup:
Port Forward Table:
[TCP] [Ext Port: 443] to [Int Port: 1443] [IP:192.168.1.23]
[TCP] [Ext Port: 80] to [Int Port: 180] [IP:192.168.1.23]
Edit: NameCheap is also setup correctly, pointing all the subdomains to honkymedia.duckdns.org, and using the IP address in the debug log for the A record. That IP was provided by DuckDNS.
Edit: I also have several subdomains for honkymedia.shop, sonarr.honkymedia.shop, radarr.honkymedia.shop, etc. All produced the same error in Lets Encrypt logs and on LetsDebug, didn't include them in the log because it would be the same error 8 times...
Hi @HonkyKONG22
are you sure your ip address is correct?
Checked your domain ( https://check-your-website.server-daten.de/?q=honkymedia.shop ):
honkymedia.shop A 185.198.126.26 Washington D.C./District of Columbia/United States (US) - US AIRFORCE INCIRLIK AIRBASE No Hostname found yes 1 0
AAAA yes
www.honkymedia.shop Name Error yes 1 0
US Airforce as ip-address?
Ok, may be wrong. But checked with another tool there is a position, so Incirlik looks correct.
And your complete domain is invisible:
185.198.126.26 -2 1.234 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 185.198.126.26:80
https://honkymedia.shop/
185.198.126.26 -2 1.233 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 185.198.126.26:443
http://honkymedia.shop/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
185.198.126.26 -2 1.243 V
Visible Content:
Not only http, same with https.
ok, so the IP address that appears in duckdns is not the IP address I should be using?
How do I know what IP address I should be using?
This may have happened because I changed my DuckDNS to a new one in an attempt to fix this, but I assume I wassn’t supposed to use the IP address that it says in DuckDNS?
EDIT: I changed the IP to my public IP and it looks like i got somewhere better with that tool, however it still isn’t getting through on port 80.
PS: Yeah, I’m at Incirlik AB right now, it’s a local national Internet provider, Air Force has IPs but not for us haha.
I don't know.
If it is a home server, then you have to use the ip address of your provider. But the Air Force Address may not work (I think or I hope, would be terrible if that would be possible).
So you need a second ip address from your national internet provider.
Now - https://check-your-website.server-daten.de/?q=honkymedia.shop - you have a new ip address:
honkymedia.shop A 65.191.18.22 Fayetteville/North Carolina/United States (US) - Spectrum Hostname: cpe-65-191-18-22.nc.res.rr.com yes 1 0
AAAA yes
But it's blocked.
Some ISP blocks such requests.
Perhaps it may be easier if you use dns-01 validation.
