Http-01 Connection refused
My domain is: webshop.janmager.keurslager.nl
I ran this command: docker run --rm -p 33586:80 -v /home/dokku/production/letsencrypt/keurslager/certs/0dda13b219cdb232b54a080da52c7390adfdd5a7:/certs dokkupaas/letsencrypt-simp_le:latest -f account_key.json -f fullchain.pem -f chain.pem -f cert.pem -f key.pem --valid_min 2592000 --server https://acme-v01.api.letsencrypt.org/directory --email my@email.com --tos_sha256 cc88d8d9517f490191401e7b54e9ffd12a2b9082ec7a1d4cec6101f9f1647e7b -d webshop.janmager.keurslager.nl
Challenge validation has failed, see error log.
Error log: https://gist.github.com/yourivdlans/0c485c3c8c32715cbf07b20ec7a78d54
My web server is (include version): nginx/1.10.3 (Ubuntu)
Ubuntu 16.04.5 LTS
Release: 16.04
Codename: xenial
tilaa.nl
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): I’m using dokku-letsencrypt which in turn uses a docker image called simp_le (https://github.com/kuba/simp_le) to issue certificates.
Lately I’m unable to request new certificates due to an error and I’m not able to figure out why.
My architecture is as follows:
HAproxy (server1) -> nginx (server2) -> Puma webserver (server2 inside docker)
Strangely enough requesting a certificate using the staging api works. I hope someone can push me in the right direction!
Thanks :slight_smile:
Hi @yourivdlans
you have ipv4 and ipv6 addresses (checked with https://check-your-website.server-daten.de/?q=webshop.janmager.keurslager.nl ):
webshop.janmager.keurslager.nl A 91.213.195.54 yes 1 0
AAAA 2a02:2770:3:0:21a:4aff:fe6d:afbe yes
www.webshop.janmager.keurslager.nl Name Error yes 1 0
Your ipv4 works. But your ipv6 doesn't.
http://webshop.janmager.keurslager.nl/
91.213.195.54 301 https://webshop.janmager.keurslager.nl:443/ 0.033 A
2a02:2770:3:0:21a:4aff:fe6d:afbe -2 1.064 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it [2a02:2770:3:0:21a:4aff:fe6d:afbe]:80
https://webshop.janmager.keurslager.nl/
91.213.195.54 200 6.636 I
2a02:2770:3:0:21a:4aff:fe6d:afbe -2 1.043 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it [2a02:2770:3:0:21a:4aff:fe6d:afbe]:443
https://webshop.janmager.keurslager.nl:443/ 200 9.236 I
http://webshop.janmager.keurslager.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
91.213.195.54 301 https://webshop.janmager.keurslager.nl:443/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.033 A
Visible Content: 301 Moved Permanently nginx
Visible Content:
https://webshop.janmager.keurslager.nl:443/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 404 7.826 A
Not Found
Checking port 80 + /.well-known/acme-challenge, ipv4 is ok (http status not found), ipv6 looks like a firewall.
But Letsencrypt prefers ipv6, so this is critical.
Two options:
  • Remove the ipv6 AAAA in your dns settings (or)
  • check, if there is a firewall, open that, check, if there is a correct answer.
This message
K http://webshop.janmager.keurslager.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 91.213.195.54, Status 301
http://webshop.janmager.keurslager.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 2a02:2770:3:0:21a:4aff:fe6d:afbe, Status -2
configuration problem - different ip addresses with different status
shouldn't be visible.
So change your configuration and recheck your domain.
Ah I see! Thanks for the quick reply.
My HAproxy was not bound to ipv6, fixing that solved the issue. Thanks again!
Yep, now you have a new certificate:
	12.03.2019
	10.06.2019
expires in 90 days	webshop.dijkstra.keurslager.nl,
webshop.eetwinkelstronkhorst.keurslager.nl, webshop.floresteijn.keurslager.nl,
webshop.janmager.keurslager.nl, webshop.jongenotter.keurslager.nl,
webshop.looman.keurslager.nl, webshop.mellegers.keurslager.nl,
webshop.pouwalmere-stad.keurslager.nl, webshop.vanelteren.keurslager.nl - 9 entries
And I’ve found a bug in my tool, so something like
style="background-image: url('picture.jpg')"
wasn’t parsed correct.
Is now fixed.
