My domain is: uplesk.citrahost.com
I ran this command: letsdebug.net
172.104.24.29 - - [28/Nov/2022:15:44:20 +0700] "GET /.well-known/acme-challenge/letsdebug-test HTTP/1.1" 200 0 "-" "Mozilla/5.0 (compatible; Let's Debug emulating Let's Encrypt validation server; +https://letsdebug.net)"
35.91.39.140 - - [28/Nov/2022:15:44:20 +0700] "GET /.well-known/acme-challenge/qCo4xpDddL0Ou8tOp1MdyV0qHWz1kqfuLjU8RpZ0Uvk HTTP/1.1" 404 268 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
13.58.204.191 - - [28/Nov/2022:15:44:20 +0700] "GET /.well-known/acme-challenge/qCo4xpDddL0Ou8tOp1MdyV0qHWz1kqfuLjU8RpZ0Uvk HTTP/1.1" 404 268 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
172.104.24.29 - - [28/Nov/2022:15:44:20 +0700] "GET / HTTP/1.1" 200 432 "-" "Go-http-client/1.1"
My web server is (include version): nginx version: nginx/1.20.2
The operating system my web server runs on is (include version): CloudLinux with CentOS 7
My hosting provider, if applicable, is: Plesk Control Panel
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk Obisidan 18.0.47
or certbot-auto --version
if you're using Certbot): Using SSLit!
I ran this command on my shell (ping)
[root@uplesk devaLE]# fping < ips.txt
acme-v02.api.letsencrypt.org is alive
ocsp.root-x1.letsencrypt.org is alive
e1.o.lencr.org is alive
e2.o.lencr.org is alive
r3.o.lencr.org is alive
r4.o.lencr.org is alive
acme-staging-v02.api.letsencrypt.org is alive
ocsp.staging-x1.letsencrypt.org is alive
ocsp.int-x3.letsencrypt.org is alive
ocsp.int-x4.letsencrypt.org is alive
oak.ct.letsencrypt.org is unreachable
sapling.ct.letsencrypt.org is unreachable
then using traceroute each IP Let's Encrypt, its produced this
[root@centos ]# traceroute to acme-staging-v02.api.letsencrypt.org (172.65.46.172), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.379 ms 0.315 ms 0.257 ms
2 103-101-136-45.as58500.net (103.101.136.45) 10.546 ms 10.622 ms 10.658 ms
3 * * *
4 * * *
27 * * *
28 * * *
29 * * *
30 * * *
[root@centos ]# traceroute to e1.o.lencr.org (23.50.117.170), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.400 ms 0.275 ms 0.208 ms
2 103.123.16.3 (103.123.16.3) 0.430 ms 0.357 ms 0.611 ms
3 cyber.dmix.bdr1.cgk.as23951.net (202.152.153.216) 8.541 ms 8.726 ms 8.738 ms
4 jktix.as23951.net (117.20.51.56) 8.780 ms 8.659 ms 8.720 ms
5 119.11.184.37 (119.11.184.37) 149.405 ms * *
6 a23-50-117-170.deploy.static.akamaitechnologies.com (23.50.117.170) 8.615 ms 8.844 ms 8.783 ms
[root@centos ]# traceroute to e2.o.lencr.org (23.50.117.170), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.316 ms 0.214 ms 0.218 ms
2 103.123.16.3 (103.123.16.3) 0.461 ms 0.350 ms 0.299 ms
3 cyber.dmix.bdr1.cgk.as23951.net (202.152.153.216) 8.599 ms 8.617 ms 8.634 ms
4 jktix.as23951.net (117.20.51.56) 8.676 ms 8.666 ms 8.619 ms
5 * 119.11.184.37 (119.11.184.37) 88.412 ms *
6 a23-50-117-170.deploy.static.akamaitechnologies.com (23.50.117.170) 8.580 ms 8.600 ms 8.665 ms
[root@centos ]# traceroute to letsencrypt.org (35.198.196.16), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.287 ms 0.233 ms 0.203 ms
2 103.123.17.170 (103.123.17.170) 0.588 ms 0.536 ms 0.462 ms
3 202-152-153-36.as23951.net (202.152.153.36) 10.542 ms 10.365 ms 10.537 ms
4 142.250.170.114 (142.250.170.114) 12.168 ms 12.190 ms 12.887 ms
5 * * *
6 * * *
29 * * *
30 * * *
[root@centos ]# traceroute to oak.ct.letsencrypt.org (3.12.255.4), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.310 ms 0.340 ms 0.243 ms
2 103.123.16.1 (103.123.16.1) 0.419 ms 0.575 ms 0.313 ms
3 202.65.112.1 (202.65.112.1) 0.570 ms 0.581 ms 0.474 ms
4 36.91.238.17 (36.91.238.17) 2.062 ms 8.133 ms 7.970 ms
5 180.240.192.33 (180.240.192.33) 45.352 ms 45.175 ms 45.329 ms
6 180.240.192.229 (180.240.192.229) 251.908 ms 251.565 ms 180.240.192.89 (180.240.192.89) 248.894 ms
7 180.240.192.89 (180.240.192.89) 248.417 ms equinix02-iad2.amazon.com (206.126.236.35) 307.459 ms 307.498 ms
8 equinix02-iad2.amazon.com (206.126.236.35) 307.132 ms 307.039 ms *
9 * * *
10 * * *
11 52.95.1.217 (52.95.1.217) 252.442 ms 52.95.1.109 (52.95.1.109) 264.557 ms *
12 52.95.2.193 (52.95.2.193) 259.918 ms 52.95.1.214 (52.95.1.214) 257.729 ms 52.95.1.163 (52.95.1.163) 253.256 ms
13 52.95.1.108 (52.95.1.108) 269.699 ms * 52.95.2.218 (52.95.2.218) 255.720 ms
14 * 52.93.130.131 (52.93.130.131) 263.129 ms 15.230.135.118 (15.230.135.118) 256.283 ms
15 54.239.42.216 (54.239.42.216) 257.332 ms 15.230.135.122 (15.230.135.122) 256.354 ms 54.239.42.98 (54.239.42.98) 256.819 ms
16 * 108.166.252.37 (108.166.252.37) 258.342 ms *
17 108.166.252.33 (108.166.252.33) 269.805 ms * *
18 * * *
19 * * *
20 * * *
21 52.95.1.187 (52.95.1.187) 262.933 ms * *
22 * * *
23 * * *
24 15.230.134.109 (15.230.134.109) 272.669 ms * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
[root@centos ]# traceroute to ocsp.int-x3.letsencrypt.org (23.50.117.177), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.282 ms 0.227 ms 0.217 ms
2 103.123.16.3 (103.123.16.3) 11.222 ms * *
3 cyber.dmix.bdr1.cgk.as23951.net (202.152.153.216) 19.185 ms * *
4 * * *
5 * * *
6 * a23-50-117-177.deploy.static.akamaitechnologies.com (23.50.117.177) 9.035 ms 8.745 ms
[root@centos ]# traceroute to ocsp.int-x4.letsencrypt.org (23.50.117.184), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.320 ms 0.383 ms 0.196 ms
2 103.123.16.3 (103.123.16.3) 0.430 ms 0.427 ms 0.376 ms
3 cyber.dmix.bdr1.cgk.as23951.net (202.152.153.216) 8.589 ms 8.597 ms 8.618 ms
4 jktix.as23951.net (117.20.51.56) 8.685 ms 8.726 ms 8.488 ms
5 119.11.184.37 (119.11.184.37) 98.022 ms 98.349 ms 98.356 ms
6 a23-50-117-184.deploy.static.akamaitechnologies.com (23.50.117.184) 8.506 ms 8.696 ms 8.798 ms
[root@centos ]# traceroute to ocsp.root-x1.letsencrypt.org (23.50.117.184), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.333 ms 0.252 ms 0.238 ms
2 103.123.16.3 (103.123.16.3) 0.422 ms 0.322 ms 0.329 ms
3 cyber.dmix.bdr1.cgk.as23951.net (202.152.153.216) 8.707 ms 8.873 ms 8.881 ms
4 jktix.as23951.net (117.20.51.56) 8.882 ms 8.851 ms 8.823 ms
5 * 119.11.184.37 (119.11.184.37) 34.358 ms *
6 a23-50-117-184.deploy.static.akamaitechnologies.com (23.50.117.184) 8.614 ms 12.110 ms 12.045 ms
[root@centos ]# traceroute to ocsp.staging-x1.letsencrypt.org (23.50.117.184), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.371 ms 0.276 ms 0.237 ms
2 103.123.16.3 (103.123.16.3) 0.434 ms 0.380 ms 0.340 ms
3 cyber.dmix.bdr1.cgk.as23951.net (202.152.153.216) 9.412 ms 9.196 ms 9.391 ms
4 jktix.as23951.net (117.20.51.56) 9.397 ms 9.438 ms 9.450 ms
5 * * *
6 a23-50-117-184.deploy.static.akamaitechnologies.com (23.50.117.184) 9.121 ms 18.895 ms *
[root@centos ]# traceroute to r3.o.lencr.org (23.50.117.168), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.350 ms 0.264 ms 0.222 ms
2 103.123.16.3 (103.123.16.3) 0.482 ms 0.398 ms 0.368 ms
3 cyber.dmix.bdr1.cgk.as23951.net (202.152.153.216) 8.612 ms 8.728 ms 8.723 ms
4 jktix.as23951.net (117.20.51.56) 8.743 ms 8.849 ms 8.711 ms
5 119.11.184.37 (119.11.184.37) 145.097 ms 145.344 ms 145.228 ms
6 a23-50-117-168.deploy.static.akamaitechnologies.com (23.50.117.168) 9.658 ms 16.415 ms 16.423 ms
[root@centos ]# traceroute to r4.o.lencr.org (23.50.117.168), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.335 ms 0.280 ms 0.233 ms
2 103.123.16.3 (103.123.16.3) 0.427 ms 0.355 ms 0.341 ms
3 cyber.dmix.bdr1.cgk.as23951.net (202.152.153.216) 8.593 ms 8.635 ms 8.647 ms
4 jktix.as23951.net (117.20.51.56) 8.630 ms 8.642 ms 8.675 ms
5 * 119.11.184.37 (119.11.184.37) 39.262 ms 38.917 ms
6 a23-50-117-168.deploy.static.akamaitechnologies.com (23.50.117.168) 12.455 ms 13.165 ms 13.202 ms
[root@centos ]# traceroute to sapling.ct.letsencrypt.org (3.13.165.167), 30 hops max, 60 byte packets
1 gateway (103.123.16.137) 0.410 ms 0.311 ms 0.228 ms
2 103.123.16.1 (103.123.16.1) 8.879 ms 8.810 ms 8.754 ms
3 * 202.65.112.1 (202.65.112.1) 8.901 ms *
4 * * *
5 * * *
6 * 180.240.192.89 (180.240.192.89) 249.162 ms 180.240.192.229 (180.240.192.229) 251.568 ms
7 180.240.192.89 (180.240.192.89) 248.789 ms equinix02-iad2.amazon.com (206.126.236.35) 305.236 ms 180.240.192.89 (180.240.192.89) 255.433 ms
8 equinix02-iad2.amazon.com (206.126.236.35) 301.147 ms 300.983 ms 301.113 ms
9 * * *
10 * * 52.95.2.182 (52.95.2.182) 266.475 ms
11 * * 52.95.1.221 (52.95.1.221) 265.844 ms
12 * * *
13 52.95.0.251 (52.95.0.251) 264.316 ms 52.95.3.3 (52.95.3.3) 259.708 ms 52.95.2.20 (52.95.2.20) 265.913 ms
14 * 15.230.140.88 (15.230.140.88) 261.580 ms *
15 * 52.93.135.152 (52.93.135.152) 258.771 ms *
16 * * *
17 * * *
18 108.166.252.35 (108.166.252.35) 258.915 ms 259.003 ms *
19 * * *
20 * * *
21 * * *
22 * * *
23 52.95.3.52 (52.95.3.52) 260.861 ms 52.95.2.16 (52.95.2.16) 254.453 ms 52.95.2.44 (52.95.2.44) 261.234 ms
24 * * *
25 108.166.252.38 (108.166.252.38) 252.459 ms * *
26 * * *
27 * * *
28 * * 108.166.252.35 (108.166.252.35) 258.136 ms
29 * * *
30 * * *
We are using 103.123.16.0/22 block IP it's clean and neutral detection by https://talosintelligence.com/reputation_center/lookup?search=103.123.16.0%2F22
also,
Nmap scan report for uplesk.citrahost.com (103.123.16.140)
Host is up (0.0023s latency).
Not shown: 984 filtered ports
PORT STATE SERVICE
21/tcp open ftp
53/tcp open domain
80/tcp open http
106/tcp open pop3pw
110/tcp open pop3
111/tcp open rpcbind
143/tcp open imap
443/tcp open https
465/tcp open smtps
587/tcp open submission
993/tcp open imaps
995/tcp open pop3s
3000/tcp open ppp
3306/tcp open mysql
8443/tcp open https-alt
see attachments for traceroute details
acme-staging-v02.api.letsencrypt.org.txt (517 Bytes)
e1.o.lencr.org.txt (499 Bytes)
e2.o.lencr.org.txt (498 Bytes)
letsencrypt.org.txt (613 Bytes)
oak.ct.letsencrypt.org.txt (1.5 KB)
ocsp.int-x3.letsencrypt.org.txt (377 Bytes)
ocsp.int-x4.letsencrypt.org.txt (529 Bytes)
ocsp.root-x1.letsencrypt.org.txt (514 Bytes)
ocsp.staging-x1.letsencrypt.org.txt (469 Bytes)
r3.o.lencr.org.txt (521 Bytes)
