Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: studiosh2o.com
The operating system my web server runs on is (include version): Ubuntu
My hosting provider, if applicable, is: Digital Ocean
or certbot-auto --version
if you’re using Certbot): 1.3.0
Hello,
I’ve been having trouble in my place since yesterday.
It seems that I have a problem with the SSL certificate.
https://www.ssllabs.com/ssltest/analyze.html?d=www.studiosh2o.com
I’ve renewed the certificate and everything is correct. But I don’t understand what’s going on. I thought it was a Let’s Encrypt problem with the certificates and that my site would be affected but when I check in:
https://checkhost.unboundtest.com/
I get the error:
unknown: dial tcp 188.226.194.196:443: i/o timeout
What could be happening?
Thank you all very much for your attention.
That shows "Assessment failed: Unable to connect to the server" right now.
The checkhost service makes a connection to your site to see what certificate you're using, and apparently it's timing out.
For me, accessing http://www.studiosh2o.com/ works (it returns a redirect to HTTPS) but accessing https://www.studiosh2o.com/ times out.
Maybe there's a firewall blocking port 443 to your website?
nmap -sT -O localhost
it gives me back:
80/tcp open http
443/tcp open https
s a firewall I use iptables
Can you connect from other parts of the Internet, though?
Edit:
Is DigitalOcean’s Cloud Firewall configured to block port 443?
nmap -sT -O 85.54.194.190 (my ip)
it gives me back:
PORT STATE SERVICE
80/tcp filtered http
135/tcp filtered msrpc
139/tcp filtered netbios-ssn
443/tcp filtered https
445/tcp filtered microsoft-ds
593/tcp filtered http-rpc-epmap
Your website’s IP is 188.226.194.196.
nmap -sT -O 188.226.194.196
it gives me back:
PORT STATE SERVICE
80/tcp open http
443/tcp open https
6666/tcp open irc
I use nmap by SSH on the server 188.226.194.196
If you ran nmap from the server, that shows that the server can connect to itself. However, other things can’t connect to it.
I don’t understand anything. Until yesterday everything was working fine. And today I find myself with this problem.
I thought it was a Let’s Encrypt problem. Well, today I got an email that said:
Sites Using a Let’s Encrypt TLS Certificate May Throw Security Warnings
How can it be a problem of a closed port if I have not touched anything and until yesterday everything was working correctly?
Rip
March 4, 2020, 5:40pm
10
Same issue from Oregon, USA
Except both http and https are timing out.
Rip
Then whose problem is it? Let’s Encrypt?
No. The timing is probably a coincidence. It’s probably some kind of firewall issue. Maybe a networking issue with your host.
Rip
March 4, 2020, 5:50pm
13
Hi @studios
@mnordhoff is right.
Coincidence.
One correction on my part though.. your http IS working but the timeout occurs after the redirect to https.
Rip
It probably means you have a firewall blocking port 443.
But until yesterday everything worked fine and I haven’t touched a thing. How can that be?
Rip
March 4, 2020, 5:57pm
17
Well something has changed!
Nmap scan report for studiosh2o.com (188.226.194.196)
Host is up (0.16s latency).
rDNS record for 188.226.194.196: frontend.studiosh2o.com
Not shown: 997 filtered ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
2222/tcp closed EtherNetIP-1
What that means is your port 443 IS filtered and needs to be opend to the public. (Your firewall most likeky)
Rip
I don’t get it.
Has only port 443 been closed?
I haven’t touched anything!
nmap 188.226.194.196
80/tcp open http
443/tcp open https
Rip
March 4, 2020, 6:03pm
20
Check with your hosting provider.
@mnordhoff asked Is DigitalOcean’s Cloud Firewall configured to block port 443?
If you see it open on your local network, and we confirm it is closed.... Check with your provider.
Rip
