Kudos for your product
Hey guys,
This is not a request, but a thank you, I was used to using Certbot on Linux before, but I'm now in a Windows Environment and i was thinking I was going to create a Linux VM to install Certbot when I saw there is a Windows version (still in Beta) and it made all the difference, I was able to do everything I needed, therefore the Thank you.
Kudos and keep up the good work.
I'm glad you found what you needed.
Just as an FYI, there are multiple clients available for Windows, not just Certbot!
@mcpherrinm just as an aside I noticed the certbot instructions for Windows currently link to the old 32 bit version of certbot, instead of the current 64-bit version.
