on jellyfin installation i have some problems
My domain is: ?
sudo certbot certonly --agree-tos --email user@email.com --no-eff-email --webroot -w /var/www/html -d media.hwdomain.io
Requesting a certificate for media.hwdomain.io
Domain: media.hwdomain.io
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for media.hwdomain.io - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for media.hwdomain.io - check that a DNS record exists for this domain
Here i am
i am not familar with linux... i try to install jellyfin from this link (So installierst du Jellyfin Media Server unter Ubuntu 22.04 – HowtoForge)
**i can run commands that is my expertise in linux XD **
The operating system my web server runs on is (include version): ubuntu 24.04.2 LTS
My hosting provider, if applicable, is: local
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): terminal
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): i dont know
letsencrypt.txt (40.1 KB)
change it from *.log to *.txt
