Issues with renewal
Hi guy's hope everyone are doing fine, i have successfully installed my certificates with your kind help 2 years ago but the auto renewal failed 2 days ago. The only change i have made recently was to cancel one of my 3 domains ''escapingthematrix.online'' so i suspect this might be my issue. Now i only have 2 domains left as for ''sortirdelamatrice.online'' and ''naos-soultrap.online''
So do i just have to delete the nginx server block in sites-availables directory for ''escapingthematrix.online'' and after issuing the command: sudo certbot renew --nginx?
Here my dry run result ;
Processing /etc/letsencrypt/renewal/sortirdelamatrice.online.conf
Plugins selected: Authenticator nginx, Installer None
http-01 challenge for sortirdelamatrice.online
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/sortirdelamatrice.online/fullchain.pem
The following certs could not be renewed:
  /etc/letsencrypt/live/escapingthematrix.online/fullchain.pem (failure)
**          (The test certificates below have not been saved.)
The following certs were successfully renewed:
  /etc/letsencrypt/live/naos-soultrap.online-0001/fullchain.pem (success)
  /etc/letsencrypt/live/naos-soultrap.online/fullchain.pem (success)
  /etc/letsencrypt/live/sortirdelamatrice.online/fullchain.pem (success)
**          (The test certificates above have not been saved.)
   Domain: escapingthematrix.online
   Type:   dns
   Detail: DNS problem: NXDOMAIN looking up A for
   escapingthematrix.online - check that a DNS record exists for this
   domain; DNS problem: NXDOMAIN looking up AAAA for
   domain
   Domain: www.escapingthematrix.online
   Type:   dns
   www.escapingthematrix.online - check that a DNS record exists for
   this domain; DNS problem: NXDOMAIN looking up AAAA for
   this domain
Well, you have actually 4 domain names you want certs for. The above 2 and their www subdomains.
It is important to remove the nginx server blocks for the obsolete domain. But, the needed Certbot command is different than that. The Certbot renew just acts on the cert profiles from your existing certs. A different command is needed to reset the old profile.
And, from the public cert history I can tell you have several different cert profiles.
We should update the cert profile you currently use and delete the other ones you don't use. Including one that was issued today.
So, let's start by you showing us the output of this
sudo certbot certificates
Hi Mike thank for replying and yes you are right the correct command should be ;
sudo certbot renew --nginx -d sortirdelamatrice.online -d www.sortirdelamatrice.online -d naos-soultrap.online -d www.naos-soultrap.online
I forgot to mention that i have tried and succeed doing a force renew command on both ''sortirdelamatrice.online'' and ''naos-soultrap.online'' but both website are still unsecured as you can see here ; https://www.sortirdelamatrice.online/
Do i have to remove both certificates before issuing a new one?
Here is the certbot certificates ;
Found the following certs:
  Certificate Name: escapingthematrix.online
    Domains: sortirdelamatrice.online escapingthematrix.online naos-soultrap.onl                                ine www.escapingthematrix.online www.naos-soultrap.online www.sortirdelamatrice.                                online
    Expiry Date: 2024-09-21 13:45:02+00:00 (INVALID: EXPIRED)
    Certificate Path: /etc/letsencrypt/live/escapingthematrix.online/fullchain.p                                em
    Private Key Path: /etc/letsencrypt/live/escapingthematrix.online/privkey.pem
  Certificate Name: naos-soultrap.online-0001
    Domains: naos-soultrap.online
    Expiry Date: 2024-12-21 23:50:04+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/naos-soultrap.online-0001/fullchain.                                pem
    Private Key Path: /etc/letsencrypt/live/naos-soultrap.online-0001/privkey.pe                                m
    Domains: naos-soultrap.online www.naos-soultrap.online
    Expiry Date: 2024-11-18 19:18:17+00:00 (VALID: 55 days)
    Certificate Path: /etc/letsencrypt/live/naos-soultrap.online/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/naos-soultrap.online/privkey.pem
  Certificate Name: sortirdelamatrice.online
    Expiry Date: 2024-12-21 23:48:46+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/sortirdelamatrice.online/fullchain.p                                em
    Private Key Path: /etc/letsencrypt/live/sortirdelamatrice.online/privkey.pem
No, that isn't the right command for your situation.
Your nginx server is using the cert profile with the name escapingthematrix.online
So, try this test and report what happens. Do not proceed beyond this yet please. Yes, I realize this profile name is for the domain you no longer use. That is not important at this stage.
sudo certbot certonly --nginx --dry-run --cert-name escapingthematrix.online -d sortirdelamatrice.online -d www.sortirdelamatrice.online -d naos-soultrap.online -d www.naos-soultrap.online
No, there are actually 4 cert profiles active but we will clean this up later.
Please stop trying that. It is not the right approach and just wasting resources.
It was successful Mike.
pierre@sortirdelamatrice:~$ ^C
pierre@sortirdelamatrice:~$ sudo certbot certonly --nginx --dry-run --cert-name escapingthematrix.online -d sortirdelamatrice.online -d www.sortirdelamatrice.online -d naos-soultrap.online -d www.naos-soultrap.online
[sudo] password for pierre:
Sorry, try again.
You are updating certificate escapingthematrix.online to include new domain(s):
(None)
You are also removing previously included domain(s):
- escapingthematrix.online
- www.escapingthematrix.online
Did you intend to make this change?
(U)pdate cert/(C)ancel: u
http-01 challenge for naos-soultrap.online
http-01 challenge for www.naos-soultrap.online
http-01 challenge for www.sortirdelamatrice.online
Excellent. Now issue same command but just omitting the --dry-run
That should get a fresh production cert and update the renewal profile
We will test that renewal and cleanup the unused cert profiles after that. One step at a time :slight_smile:
It was successful again Mike but is there a propagation time period since the websites are still unsecured?
EDIT; my mistake i forgot to reload nginx now it's working fine.
pierre@sortirdelamatrice:~$ sudo certbot certonly --nginx --cert-name escapingthematrix.online -d sortirdelamatrice.online -d www.sortirdelamatrice.online -d naos-soultrap.online -d www.naos-soultrap.online
(None)
   Your cert will expire on 2024-12-22. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot
   again. To non-interactively renew *all* of your certificates, run
   "certbot renew"
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
Nice fix and nice use of --dry-run for testing, @MikeMcQ!
Excellent. I confirm I see the new cert with 4 domains used by your nginx. Now, to finish up. Let's delete the unused cert profiles. Certbot will try to renew each of them until we delete them. You don't need these certs since those names are covered in your other cert.
So, issue these 3 commands
sudo certbot delete --cert-name naos-soultrap.online-0001
sudo certbot delete --cert-name sortirdelamatrice.online
And, when done with those show output of this to confirm the automated renew works properly
sudo certbot renew --dry-run
All good Mike and here the dry run result;
Deleted all files relating to certificate naos-soultrap.online-0001.
pierre@sortirdelamatrice:~$ sudo certbot delete --cert-name naos-soultrap.online
Deleted all files relating to certificate naos-soultrap.online.
pierre@sortirdelamatrice:~$ sudo certbot delete --cert-name sortirdelamatrice.online
Deleted all files relating to certificate sortirdelamatrice.online.
pierre@sortirdelamatrice:~$ sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/escapingthematrix.online.conf
new certificate deployed with reload of nginx server; fullchain is
  /etc/letsencrypt/live/escapingthematrix.online/fullchain.pem (success)
Here the certificates;
pierre@sortirdelamatrice:~$ sudo certbot certificates
    Domains: sortirdelamatrice.online naos-soultrap.online www.naos-soultrap.online www.sortirdelamatrice.online
    Expiry Date: 2024-12-22 22:36:15+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/escapingthematrix.online/fullchain.pem
Excellent. Looks good. Should be fine going forward.
Thank a lot Mike your support is simply fantastic! I just have 2 more questions and i am done ;
1- Can i now delete the escapingthematrix.online.conf from nginx sites availables?
2- I wont to donate but there is 2 links one is ```
Donating to ISRG / Let's Encrypt: Additional Donation Information - Let's Encrypt
and the other is ; ```
So what is the difference between the 2 links?
If that is the server block for that obsolete domain then yes. Usually people have a symlink in /sites-enabled to the /sites-available folder. If you have that you should remove that first.
Then try sudo nginx -t to test your nginx conf.
Let's Encrypt is the Certificate Authority (CA). It is what manages and issues the certs. It is run by the ISRG. Who also operate this forum :slight_smile:
Certbot is developed by the EFF. At one time it was done by ISRG too but the EFF have handled it for a long time.
Donations are not required but I am sure both organizations appreciate them. Pick your favorite or even split your intended amount to each.
OK that's fine with me i will split to both and with that kind of support it's the least we can do!
Perfect and thank again for helping me putting back those websites securely online, have a good week.
Regards Peter
