Certbot auto renew issue
cmsmesh.com
cmsmesh.com-0001.conf content :
[renewalparams]
account = abc........
pref_challs = dns-01,
authenticator = manual
manual_public_ip_logging_ok = True
sudo certbot renew --dry-run --nginx
Processing /etc/letsencrypt/renewal/cmsmesh.com-0001.conf
Attempting to renew cert (cmsmesh.com-0001) from /etc/letsencrypt/renewal/cmsmesh.com-0001.conf produced an unexpected error: None of the preferred challenges are supported by the selected plugin. Skipping.
/etc/letsencrypt/live/cmsmesh.com-0001/fullchain.pem (failure)
nginx/1.18.0 (Ubuntu)
Ubuntu 20.04.2 LTS
DigitalOcean
no
certbot 0.40.0
The following certificate options (mainly the pref_challs setting), set when you first got the certificate:
is not compatible with the:
option. Because the nginx authenticator does not provide the dns-01 challenge.
When I check the certificates for your domain at crt.sh | cmsmesh.com I can see three certs: a non-wildcard due for renewal and a wildcard cert due for renewal and one which is just renewed.
My question to you would be: which one did you want to renew? The wildcard certificate or the non-wildcard certificate? But it seems you already managed to (manually?) renew your wildcard certificate.
Thanks for your response.
yes, i have done via this command :
certbot certonly --manual --manual-auth-hook /etc/letsencrypt/acme-dns-auth.py --agree-tos --manual-public-ip-logging-ok --preferred-challenges dns --server https://acme-v02.api.letsencrypt.org/directory --debug-challenges -d cmsmesh.com -d *.cmsmesh.com
My question is, by using the hook that's mean the auto-renew will also works?
Thank you
Yes, using the hook enables certbot to auto-renew using the manual plugin. That said, I don't see a --manual-cleanup-hook which is required to delete the TXT records which were added using the --manual-auth-hook. Does that script acme-dns-auth.py also have the ability to delete the TXT records once they aren't necessary any longer? Or is that not required when using acme-dns? (I have no idea..)
In fact i pursued this tutorial https://cloudness.net/certbot-dns-challenge/, and sorry i don't have any idea about --manual-cleanup-hook.
So the auto-renew will be launched by pre-installed cron task /etc/cron.d/certbot right?
Tell me if i'm doing something wrong.
Thank you
I think you can forget about that cleanup hook. I don't see anything related to that hook on the Github README pages of acme-dns nor that of acme-dns-certbot (the script you're using). So perhaps it isn't required for acme-dns.
It depends on the method you've used to install certbot if there's such a cron task installed or not. For example, on Gentoo there is no such pre-installed cronjob.
Thank you for your help.
I see, i'm using ubuntu, and /etc/cron.d/certbot is there, so i hope that i'm doing the right things.
Thanks
