Issues with recent renewal
My domain is: douganconsulting.com
certbot certonly --manual --expand --preferred-challenges dns-01 -d .douganconsulting.com,douganconsulting.com,.douganfamily.org,.intelligenttechnology.ca,.teresadougan.com,*.vancouvershamrockcsc.org
After making the normal DNS changes, all seemed to work. This is not a new setup - I've been running it for several years.
N/A
Yes
No
certbot 2.11.0
I ran the manual process yesterday as normal, and it seemed to work well. My post-certbot script ran and copied the certs to my other servers, and I restarted their services as needed.
That said, two functions are no longer working - my Unifi server and my mail server (the Web server on the same box shows the new certs correctly). The mail server now shows a self-cert rather than the LE one (though nothing has changed on the host), while my Unifi server (used to manage my Ubiquiti Unifi switches and APs) no longer responds.
The only thing that seems different is that the certs now show "Issued by: E5", rather than "R3" as previously. Is this change in any way significant?
My best guess is that since you are not renewing the cert [doing certonly and --expand], certbot is simply issuing a new cert; As such, the new default for certs is no longer RSA.
Your systems are likely not instantly compatible with the new cert type [ECDSA].
You could research how to get them to use such ECDSA certs [a good long-term solution].
OR
You could reissue the cert and request it as type RSA [simple short-term solution].
Thank you - I will check that now.
Des
rg305 - thank you for your help. That was indeed the issue.
