Changing renewal process
douganconsulting.com
certbot-auto certonly --manual --preferred-challenges dns-01 -d *.douganconsulting.com
It worked as expected.
Apache 2.4.37
CentOS 8
Yes
1.10.1
As noted above, I have been using the --manual option on this server (acting as a proxy, as I have several Web sites and subdomains hosted on my office LAN). While this works, it is not something I can automate. I've read the various posting and articles I can find but I'm not getting what I am looking for - which is a way to renew the certs automatically via a cron job. Can anyone point me to a way to amend what I have in place? I think, from what I understand from this site, that using the wildcard is not a good idea in terms of automation. Am I reading that correctly?
Thanks,
Des
Hello Des :slightly_smiling_face:
While dns-01 challenges (which are required for wildcard domain names) can be automated, making that happen can be far more complex than by simply using http-01 challenges.
Since you appear to be using a reverse proxy (with everything behind the reverse proxy being local), I recommend terminating SSL/TLS and serving all of the certificates via SNI at the reverse proxy. By the way, certbot-auto is deprecated and may cause you headaches going forward.
certbot-auto run -a apache -d "douganconsulting.com,www.douganconsulting.com" -i apache --keep
Hello @ddougan,
I'm leaving right now so my response will be short.
Seems you are using zoneedit as your dns provider and I'm afraid zoneedit doesn't provide an API to create/modify/etc. the DNS records so seems you can't automate it, at least not in an easy way.
Also, as zoneedit doesn't provide an api, there isn't certbot plugins to automate the DNS validation, not even in acme.sh client and it has tons of dns plugins.
You could move your dns to cloudflare for example, it is free and certbot provides a plugin to automate it.
There are other options like use dns alias mode so if you can't or simply don't want to change your dns provider we could use those other options.
I'm sorry but family is waiting for me :wink:
Happy New Year!
Cheers,
sahsanu
Thanks, Griffin. I had no clue that certbot-auto had been deprecated - I'll look at snap now that I know about it. I'll also look at SNI on my Apache configuration - many thanks for your assistance.
Des
Hi Sahsanu,
Thanks the the ideas. I've been happy with ZoneEdit for a long time, but it may be time for a new provider based on the lack of API.
Happy New Year!
Regards,
Des
You can also delegate the ACME DNS challenge to another domain through CNAME records or even to a whole different DNS server with NS records. It might be possible to keep your main DNS stuff @ ZoneEdit and only put the ACME bit at for example CloudFlare or another API providing DNS service. You might also look at acme-dns which is build for exactly this purpose (mainly for security reasons).
