Hi to everyone after a check operation over the site the Security Scorecard i found these issues related to certificate:
Certificate is self signed
Certificate Lifetime is longher than Best Practises
Certificate dosen't have revocation control.
The fact is that i purchased this certificate recently and i don't understand how it's possible that a new certificate can have these kind of issue.
Thanks in advance !
Hello @wanciu
Please share your domain and other info requested.
We can help you resolve your issue
Rite-oh! Ill fix my blank.
And on the current thread, I'm just trying to be fair and give the benefit of the doubt. What would bring someone here and not to another CA?
@wanciu, it's very likely that your new certificate was issued but not installed on your server. The certificate is a file which needs to be obtained from the certificate authority and then installed appropriately onto the web server, including by making changes to the web server configuration. Otherwise, it just exists but doesn't accomplish anything.
Since your "Certificate is self signed" the one being served by your server is probably not the same one that you purchased.
As other people have pointed out, you might be on the wrong forum because this is the forum for the Let's Encrypt CA, a particular not-for-profit CA which does not charge anyone for its certificates. So if you paid for your certificate, you probably got it from someone else—and it would be more appropriate to ask for support on the forum for that CA instead of Let's Encrypt.
