Hi @TimurR
I see a self signed certificate.
You have created 3 Letsencrypt certificates ( https://check-your-website.server-daten.de/?q=ultifree.ml#ct-logs )
| Issuer |
not before |
not after |
Domain names |
LE-Duplicate |
next LE |
| Let's Encrypt Authority X3 |
2019-07-09 |
2019-10-07 |
status.ultifree.ml - 1 entries |
duplicate nr. 1 |
2019-07-09 |
2019-10-07 |
ultifree.ml, www.ultifree.ml - 2 entries |
duplicate nr. 2 |
2019-07-08 |
2019-10-06 |
duplicate nr. 1 |
but checking your domain there is a self signed:
<html><body><script type="text/javascript" src="/aes.js" ></script><script>function toNumbers(d){var e=[];d.replace(/(..)/g,function(d){e.push(parseInt(d,16))});return e}function toHex(){for(var d=[],d=1==arguments.length&&arguments[0].constructor==Array?arguments[0]:arguments,e="",f=0;f<d.length;f++)e+=(16>d[f]?"0":"")+d[f].toString(16);return e.toLowerCase()}var a=toNumbers("f655ba9d09a112d4968c63579db590b4"),b=toNumbers("98344c2eee86c3994890592585b49f80"),c=toNumbers("1c167956de3e1144501be14a7c38a53a");document.cookie="__test="+toHex(slowAES.decrypt(c,2,a,b))+"; expires=Thu, 31-Dec-37 23:55:55 GMT; path=/"; location.href="https://ultifree.ml/?i=1";</script><noscript>This site requires Javascript to work, please enable Javascript in your browser or use a browser with Javascript support</noscript></body></html>
|• https://www.ultifree.ml/
185.27.134.208|200||0.467|N|
|Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors|
And the included JavScript (visible checking http://ultifree.ml/.well-known/acme-challenge/random-filename) looks like your hoster blocks /.well-known/acme-challenge.
So it may be impossible that you install the certificate.
What's your configuration?
