NET::ERR_CERT_AUTHORITY_INVALID issue appearing - was working after initial install a couple days ago
I tried using LetsEncrypt free SSL for the first time on 15 sites I’m working on. I used certbot to install an SSL cert on all 15 of theses sites 2 days ago. Things went extremely smooth and everything was working perfectly. However, it appears that as of this morning, browsers are now displaying an insecure error with the following error: NET::ERR_CERT_AUTHORITY_INVALID
https://realestate.heraldnet.com/
None
None
Litespeed 5.3.8 (backup Apache/2.4.39)
CentOS 6.10
GoDaddy
Yes
WHM - cPanel
certbot 0.34.2
Could you please logon to GoDaddy cPanel and check the certificate listed in cPanel -> TLS/SSL status?
It seems that now it’s been reverted back to the original self-signed certificate…
Thank you
Hi @avweb
that's curious. Checking your domain there is a self signed cPanel-certificate ( https://check-your-website.server-daten.de/?q=realestate.heraldnet.com ):
CN=realestate.heraldnet.com
	17.05.2019
	16.05.2020
expires in 352 days
realestate.heraldnet.com, mail.realestate.heraldnet.com,
www.realestate.heraldnet.com, webmail.realestate.heraldnet.com,
cpanel.realestate.heraldnet.com, webdisk.realestate.heraldnet.com - 6 entries
If you use cPanel, you shouldn't use Certbot directly.
And you have a Letsencrypt certificate with 15 domain names:
Perhaps your hoster has updated the cPanel.
Check your cPanel if there is an option to create a Letsencrypt certificate. Then use that.
Also, as @JuergenAuer said, if you are using cPanel, you aren’t supposed to edit / touch Apache / LSWS files directly, as it will not stay unchanged after reboot / restart / reload.
You should try to either obtained the certificate and update it in cPanel interface manually, or use cPanel api to directly update the certificate from command-line.
acme.sh (another third party acme script) have support for cPanel API.
Thank you
Ok, That makes sense. I will speak with my hosting provider to see if they have a way to set it up within cPanel, as I’m not seeing any LetsEncrypt integration tools in cPanel currently, just the standard, upload/ install a certificate options.
Hosting provider has stated they do not support 3rd Party SSL and cannot provide assistance… is there any documentation on the cPanel route?
Allows your cPanel a manual import? If yes, you can create a certificate via Certbot (with Certonly, without installation) and upload it. But you have to do that every 60 - 85 days.
I was able to download a WHM plugin for Let’s Encrypt. AutoSSL is now set up and everything appears to be working. Thanks for your help!
