Hi "LetsEncrypt" Team,
Your Service is amazing...
We are renewed the certificate 14 hours before it's expire. Now we are facing the following Error.
" (failed) net::ERR_CERT_AUTHORITY_INVALID "
My domain is: b2bmobilelab.com
certbot renew
certbot renew --cert-name b2bmobilelab.com --dry-run
Congratulations, all simulated renewals succeeded.
C:\Certbot\live\b2bmobilelab.com\fullchain.pem (success)
The operating system my web server runs on is (include version): Windows 11
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot --version 1.31.0
rg305
January 13, 2023, 7:16am
3
Hi @SanthoshKumar , and welcome to the LE community forum
It's kind of hard for me to see what it throwing that error message.
Is the problem seen over the Internet OR within the same LAN OR both?
There is a self-signed cert seen being server over port 443 now over the Internet.
See:
SSL Server Test: b2bmobilelab.com (Powered by Qualys SSL Labs)
yeah its seen over the internet
rg305
January 13, 2023, 7:25am
5
Well, then whatever is serving that certificate needs to be instructed to serve the real [renewed] certificate.
Is there any period of time to activate for certificate after renewed...
9peppe
January 13, 2023, 11:49am
7
Not from Let's Encrypt's side.
But the new certificate has to be installed on your server. What http server software are you using?
I would expect
Did you after using the Staging Environment actually get a production issued Certificate and install it in you web server to serve the new Certificate?
(likely needing to restart the web server).
Here is a list of issued certificates crt.sh | b2bmobilelab.com , the latest being 2022-10-15 .
How did you obtain that certificate?
system
Closed
February 12, 2023, 5:54pm
11
