Issues with certbot
My domain is: hellmanx.ddns.net (using port 3670 for web server)
I ran this command: sudo certbot --nginx -v
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): hellmanx.ddns.net:3670
Requesting a certificate for hellmanx.ddns.net:3670
http-01 challenge for hellmanx.ddns.net
Challenge failed for domain hellmanx.ddns.net
Domain: hellmanx.ddns.net
Type: connection
Detail: 73.214.218.190: Fetching http://hellmanx.ddns.net/.well-known/acme-challenge/Yx29szpQMW2l_bdaPhplKeoXeh2-F4avYVBuX_HTLyQ: Timeout during connect (likely firewall problem)
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version):Debian 6.0.12- 1~bpo11+1 (2022-12-19) x86_64
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 2.5.0
You need to configure your Comcast internet connection to route ports 80 and 443 to your Debian server. Your webserver needs to be accessible from the internet.
This is usually done by "port forwarding" on your modem/router. It also requires that your Comcast service does not intentionally block you from using these ports.
Irrespective of what port you want to install the certificate on, you need to perform the HTTP challenge over port 80.
Everything is already working correctly. I am using port forwarding to access the webserver right now. I need the certification signed so I don't have that browser warning every so often.
I'll try moving the webserver to port 80 to get the challenge done if that's what's needed. I'll move it back to port 3670 afterward.
I'm just wondering how an auto-renewal will work if certbot doesn't like using specified ports.
Using the online tool Let's Debug yields these results https://letsdebug.net/hellmanx.ddns.net/1439576
ANotWorking
Error
hellmanx.ddns.net has an A (IPv4) record (73.214.218.190) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
A timeout was experienced while communicating with hellmanx.ddns.net/73.214.218.190: Get "http://hellmanx.ddns.net/.well-known/acme-challenge/letsdebug-test": context deadline exceeded
Trace:
@0ms: Making a request to http://hellmanx.ddns.net/.well-known/acme-challenge/letsdebug-test (using initial IP 73.214.218.190)
@0ms: Dialing 73.214.218.190
@10000ms: Experienced error: context deadline exceeded
IssueFromLetsEncrypt
Error
A test authorization for hellmanx.ddns.net to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
73.214.218.190: Fetching http://hellmanx.ddns.net/.well-known/acme-challenge/dvJZMP1UJgTAZcUF2ueZviSoWHsJzCLe7ScOdXjNjeY: Timeout during connect (likely firewall problem)
Also using this online tool Open Port Check Tool - Test Port Forwarding on Your Router shows All Common Ports are closed.
Well, right. The web server is running on port 3670.
I'll have to switch it to port 80 to do the challenge and then switch it back after certbot finishes
But there is definitely something running on port 443. Not sure why that says it's closed.
Hi @Hellman_x, sorry I miss understood
Using nmap -Pn hellmanx.ddns.net I see:
$ nmap -Pn hellmanx.ddns.net
Starting Nmap 7.80 ( https://nmap.org ) at 2023-04-09 18:01 UTC
Nmap scan report for hellmanx.ddns.net (73.214.218.190)
Host is up (0.090s latency).
rDNS record for 73.214.218.190: c-73-214-218-190.hsd1.pa.comcast.net
Not shown: 998 filtered ports
PORT     STATE SERVICE
444/tcp  open  snpp
7777/tcp open  cbt
Nmap done: 1 IP address (1 host up) scanned in 125.58 seconds
443 is for my router. It must be set to drop ICMP packets on that port.
Well using TCP Port 443 (via sudo traceroute -T -p 443 hellmanx.ddns.net) I get the same basic results.
$ sudo traceroute -T -p 443 hellmanx.ddns.net
traceroute to hellmanx.ddns.net (73.214.218.190), 30 hops max, 60 byte packets
 1  192.168.1.1 (192.168.1.1)  0.196 ms  0.145 ms  0.171 ms
 2  96.120.60.137 (96.120.60.137)  7.769 ms  7.756 ms  7.742 ms
 3  ae-312-1258-rur102.beaverton.or.bverton.comcast.net (68.87.217.41)  7.914 ms  7.901 ms  7.932 ms
 4  68.85.243.153 (68.85.243.153)  7.869 ms  7.854 ms  7.840 ms
 5  96.216.60.113 (96.216.60.113)  7.826 ms  7.691 ms  7.677 ms
 6  24.124.129.62 (24.124.129.62)  7.662 ms  12.514 ms  12.495 ms
 7  ae-69-ar01.troutdale.or.bverton.comcast.net (68.85.243.197)  17.370 ms  16.192 ms  12.235 ms
 8  be-36221-cs02.seattle.wa.ibone.comcast.net (68.86.93.53)  15.654 ms be-36231-cs03.seattle.wa.ibone.comcast.net (68.86.93.57)  15.362 ms be-36241-cs04.seattle.wa.ibone.comcast.net (68.86.93.61)  15.306 ms
 9  be-1211-cr11.seattle.wa.ibone.comcast.net (96.110.47.190)  15.269 ms be-1111-cr11.seattle.wa.ibone.comcast.net (96.110.47.178)  15.350 ms  15.322 ms
10  be-302-cr11.champa.co.ibone.comcast.net (96.110.36.213)  40.142 ms  39.829 ms  40.084 ms
11  be-1311-cs03.champa.co.ibone.comcast.net (96.110.37.201)  40.481 ms be-1411-cs04.champa.co.ibone.comcast.net (96.110.37.205)  41.099 ms  39.370 ms
12  be-1413-cr13.champa.co.ibone.comcast.net (96.110.37.238)  38.664 ms be-1414-cr14.champa.co.ibone.comcast.net (96.110.37.254)  38.401 ms be-1213-cr13.champa.co.ibone.comcast.net (96.110.37.230)  37.993 ms
13  be-304-cr13.1601milehigh.co.ibone.comcast.net (96.110.36.206)  39.686 ms be-304-cr14.1601milehigh.co.ibone.comcast.net (96.110.39.14)  39.640 ms be-301-cr13.1601milehigh.co.ibone.comcast.net (96.110.36.194)  39.865 ms
14  be-1314-cs03.1601milehigh.co.ibone.comcast.net (96.110.39.121)  39.836 ms be-1214-cs02.1601milehigh.co.ibone.comcast.net (96.110.39.117)  39.809 ms be-1314-cs03.1601milehigh.co.ibone.comcast.net (96.110.39.121)  40.801 ms
15  be-1211-cr11.1601milehigh.co.ibone.comcast.net (96.110.39.70)  36.695 ms be-1111-cr11.1601milehigh.co.ibone.comcast.net (96.110.39.66)  40.236 ms be-1211-cr11.1601milehigh.co.ibone.comcast.net (96.110.39.70)  40.063 ms
16  be-304-cr21.350ecermak.il.ibone.comcast.net (96.110.37.157)  71.490 ms be-303-cr21.350ecermak.il.ibone.comcast.net (96.110.37.153)  72.803 ms  73.163 ms
17  be-1321-cs23.350ecermak.il.ibone.comcast.net (68.86.82.249)  74.933 ms  74.894 ms be-1221-cs22.350ecermak.il.ibone.comcast.net (68.86.82.245)  73.289 ms
18  be-1124-cr24.350ecermak.il.ibone.comcast.net (68.86.84.138)  73.470 ms be-1324-cr24.350ecermak.il.ibone.comcast.net (68.86.84.170)  73.603 ms be-1424-cr24.350ecermak.il.ibone.comcast.net (68.86.84.174)  72.743 ms
19  be-301-cr12.pittsburgh.pa.ibone.comcast.net (96.110.39.158)  81.973 ms  81.938 ms be-302-cr12.pittsburgh.pa.ibone.comcast.net (96.110.39.162)  82.303 ms
20  be-1212-cs02.pittsburgh.pa.ibone.comcast.net (96.110.38.149)  82.536 ms  80.551 ms  71.020 ms
21  96.110.42.174 (96.110.42.174)  74.461 ms be-31621-ar01.mckeesport.pa.pitt.comcast.net (96.110.42.166)  74.479 ms  71.112 ms
22  po-1-xar02.blairsville.pa.pitt.comcast.net (162.151.152.66)  76.406 ms  76.390 ms  76.306 ms
23  po-1-rur202.blairsville.pa.pitt.comcast.net (96.216.140.194)  76.036 ms  76.346 ms  76.140 ms
24  68.86.102.10 (68.86.102.10)  76.317 ms  75.979 ms  76.219 ms
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
Whereas for Port 3670 (via sudo traceroute -T -p 3670 hellmanx.ddns.net) I get through.
$ sudo traceroute -T -p 3670 hellmanx.ddns.net
 1  192.168.1.1 (192.168.1.1)  0.201 ms  0.190 ms  0.218 ms
 2  96.120.60.137 (96.120.60.137)  7.608 ms  7.593 ms  7.580 ms
 3  ae-312-1258-rur102.beaverton.or.bverton.comcast.net (68.87.217.41)  7.565 ms  7.552 ms  13.649 ms
 4  68.85.243.153 (68.85.243.153)  13.634 ms  13.621 ms  13.608 ms
 5  96.216.60.113 (96.216.60.113)  7.483 ms  7.470 ms  13.566 ms
 6  24.124.129.62 (24.124.129.62)  7.439 ms  18.921 ms  18.902 ms
 7  ae-69-ar01.troutdale.or.bverton.comcast.net (68.85.243.197)  31.566 ms  9.510 ms  13.714 ms
 8  be-36211-cs01.seattle.wa.ibone.comcast.net (68.86.93.49)  17.497 ms be-36231-cs03.seattle.wa.ibone.comcast.net (68.86.93.57)  16.804 ms  16.784 ms
 9  be-1411-cr11.seattle.wa.ibone.comcast.net (96.110.47.214)  17.409 ms be-1111-cr11.seattle.wa.ibone.comcast.net (96.110.47.178)  17.377 ms  17.347 ms
10  be-302-cr11.champa.co.ibone.comcast.net (96.110.36.213)  40.628 ms be-301-cr11.champa.co.ibone.comcast.net (96.110.36.209)  41.506 ms  40.627 ms
11  be-1211-cs02.champa.co.ibone.comcast.net (96.110.37.197)  40.573 ms  40.533 ms  40.493 ms
12  be-1413-cr13.champa.co.ibone.comcast.net (96.110.37.238)  40.461 ms be-1314-cr14.champa.co.ibone.comcast.net (96.110.37.250)  41.006 ms be-1213-cr13.champa.co.ibone.comcast.net (96.110.37.230)  37.714 ms
13  be-304-cr14.1601milehigh.co.ibone.comcast.net (96.110.39.14)  37.653 ms be-303-cr14.1601milehigh.co.ibone.comcast.net (96.110.39.10)  37.620 ms be-304-cr13.1601milehigh.co.ibone.comcast.net (96.110.36.206)  37.593 ms
14  be-1114-cs01.1601milehigh.co.ibone.comcast.net (96.110.39.113)  37.559 ms be-1113-cs01.1601milehigh.co.ibone.comcast.net (96.110.39.97)  37.531 ms be-1413-cs04.1601milehigh.co.ibone.comcast.net (96.110.39.109)  37.513 ms
15  be-1311-cr11.1601milehigh.co.ibone.comcast.net (96.110.39.74)  37.498 ms be-1411-cr11.1601milehigh.co.ibone.comcast.net (96.110.39.78)  38.968 ms be-1211-cr11.1601milehigh.co.ibone.comcast.net (96.110.39.70)  38.040 ms
16  be-302-cr21.350ecermak.il.ibone.comcast.net (96.110.37.149)  65.413 ms be-304-cr21.350ecermak.il.ibone.comcast.net (96.110.37.157)  65.588 ms *
17  be-1321-cs23.350ecermak.il.ibone.comcast.net (68.86.82.249)  66.329 ms  66.289 ms be-1121-cs21.350ecermak.il.ibone.comcast.net (68.86.82.241)  67.169 ms
18  be-1224-cr24.350ecermak.il.ibone.comcast.net (68.86.84.142)  60.185 ms  62.362 ms  62.298 ms
19  be-301-cr12.pittsburgh.pa.ibone.comcast.net (96.110.39.158)  71.679 ms  71.623 ms  76.286 ms
20  be-1112-cs01.pittsburgh.pa.ibone.comcast.net (96.110.38.145)  75.547 ms be-1412-cs04.pittsburgh.pa.ibone.comcast.net (96.110.38.157)  76.220 ms be-1312-cs03.pittsburgh.pa.ibone.comcast.net (96.110.38.153)  72.973 ms
21  be-31621-ar01.mckeesport.pa.pitt.comcast.net (96.110.42.166)  73.339 ms  72.917 ms 96.110.42.174 (96.110.42.174)  72.902 ms
22  po-1-xar02.blairsville.pa.pitt.comcast.net (162.151.152.66)  73.294 ms  73.269 ms  78.052 ms
23  po-1-rur202.blairsville.pa.pitt.comcast.net (96.216.140.194)  74.545 ms  70.591 ms  76.023 ms
24  68.86.102.10 (68.86.102.10)  75.450 ms  75.368 ms  75.906 ms
25  c-73-214-218-190.hsd1.pa.comcast.net (73.214.218.190)  88.531 ms  88.471 ms  88.435 ms
26  c-73-214-218-190.hsd1.pa.comcast.net (73.214.218.190)  93.719 ms  93.611 ms  98.296 ms
Oh, yeah. Forgot to mention I left the port closed overnight. Have friends that use it, don't need passwords going though HTTP. Could've just used the self-signed cert though.
Looks like I can't use port 80. Must be conflicting with another web server I have running LAN wise.
Is there any way I'm able to make Certbot do a challenge on a port rather than an expected port?
No; from here HTTP-01 challenge. Sorry. :frowning:
That's kind of a pain. Beggers can't be choosers I guess. I suppose I could put it on a different VLAN to try and solve that conflict issue.
Or if I really want to make it complicated, I could always to a reverse proxy with stunnel.
There are other Free ACME Certificate Authorities you might look at
Or a different Challenge the DNS-01 of the Challenge Types - Let's Encrypt
Here is a list of DNS providers who easily integrate with Let's Encrypt DNS validation
Note that publicly-trusted CAs are very limited in what TCP ports they are allowed to use for proof-of-control challenges. Search for "Authorized Ports" in
Let's Encrypt already supports 2/3 of those that are likely to work on residential ISP hosting. :slight_smile:
Also, the ACME standard allows HTTP-01 challenges only on port 80 and TLS-ALPN-01 challenges only on port 443.
https://www.rfc-editor.org/rfc/rfc8555#section-8.3
While it's true that Let's Encrypt-associated people originally helped write all of these rules, the industry rules do rather strictly limit the port numbers that are allowed to be used, so it can't quite be considered an arbitrary preference on Let's Encrypt's part. These same restrictions will be enforced by other CAs as well.
I'll try a reverse proxy then. That should solve this.
