Error generating certificate with certbot command. Help
I am trying to generate a certificate using the web server method.
The default(80/443) ddns.net is occupied by NAS. So you need to use a different port.
$ sudo certbot --nginx -d xxxx.ddns.net:18080 -v
Requesting a certificate for xxxx.ddns.net:18080
http-01 challenge for xxxx.ddns.net
Challenge failed for domain xxxx.ddns.net
  Domain: xxxx.ddns.net
  Type:   unauthorized
  Detail: xxx.xxxx.xxx.xxx: Invalid response from http://xxxx.ddns.net/.well-known/acme-challenge/SbXU_DWIEH1hljJ7PxhP5XGQkSZSoATvdjhVKBCqtoI: 404
It is not normally created like this.
Below is the nginx configuration.
nginx.conf
        listen 18080 default_server;
        listen [::]:18080 default_server;
        root /var/www/html;
        index index.nginx-debian.html;
        server_name xxxx.ddns.net;
                try_files $uri $uri/ =404;
Please let me know if this problem is because the port of the address is not recognized or if I need to do another option. [ ex : http://xxxx.ddns.net/.well-known/acme-challenge/SbXU_DWIEH1hljJ7PxhP5XGQkSZSoATvdjhVKBCqtoI
-> http://xxxx.ddns.net:18080/.well-known/acme-challenge/SbXU_DWIEH1hljJ7PxhP5XGQkSZSoATvdjhVKBCqtoI ]
Hi @JH-Kim88, and welcome to the LE community forum :slight_smile:
HTTP-01 authentication must be done on port 80.
TLS-APLN-01 authentication must be done on port 443.
That leaves you with three choices:
  1. DNS-01 authentication which is not as simple as the other two and, for automation, requires a DSP that allows DNS zone updates via API.
  2. Proxy the xxxx.ddns.net challenge requests within the NAS to the other system.
  3. Insert an HTTP proxy in front of both [NAS and new system]
