Hi all, I have been trying to update the certificate on my FreePBX server and am having a lot of problems. I learned that it was probably because I needed to open port 80 on my firewall to allow updates, but I went into my settings and allowed incoming traffic from port 80 and was still timing out on request. Now I can no longer troubleshoot this issue because I have gotten the error below statting that I cannot request anymore certs for this domain. I understand I can only get 5 per week, but I never actually got to use these 5 I requested. What can I do? I need to get this cert updated.
I ran this command: I am in GUI trying to renew the cert
It produced this output: I was getting that my request was timing out, but am now getting “There was an error updating the certificate: 429 { “type”: “urn:ietf:params:acme:error:rateLimited”, “detail”: “Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/”, “status”: 429 }”
My web server is (include version): freePBX 15.0.16.52
The operating system my web server runs on is (include version): Linux (I am unsure of the version)
I can login to a root shell on my machine (yes or no, or I don’t know): Having problems getting in
I am no longer getting the other error message, so I cannot recall fully what it was. The biggest problem now is that I cannot attempt to get more certifications it seems.
I read the part about clearing pending authorizations, but I do not see the log reports in FreePBX. I just took this over from our previous Admin, and I am trying to wrap my head around it.
I am sorry, I misread the document. I thought pending authorizations was an issue within the same problem. So if that is not the case, the only thing I can do is wait until Monday to try again, and if I cannot fix the other problem and it happens again, wait another week?
Wow I am bad at reading this documentation. Sorry, I promise I am not usually this dense haha. Was just getting frustrated and in a hurry. I am going to use the hour to break off it for a bit to get a fresh look, and will update when the other error comes back.
I now have the other error. I am getting “There was an error updating the certificate: Verification timed out” and I see that this is repeated a few times before it times out " signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/4890977181/sWwliQ Verification pending, sleeping 1s".
I have created a port forwarding rule on my firewall that points all incoming port 80 traffic to my FreePBX server. port 80 is opened on the server itself, and in system admin, I have let encrypt set to port 80, and I have a custom service opening port 80
