Certificate for freepbx
My domain is:grahome@ralphgraham.org
certificate update
failed
freepbx, all worked for 2 years no problem
installed unifi USG gateway and with port 80 forwarded unable to renew
Can you be a little bit more detailed; perhaps show us a picture of the menu choice.
Sorry rg305 there is no menu to show. The letsencrypt certificate is on my freepbx server. It is giving a warning that an update failed. I have not had this problem before. When I click on update certificate button the message is certificate failed.
The only chnage I have made is to install a Unifi USG gateway. I have set a port forward rule for port 80.
I do not know what else to try.
Thanks
I would suggest you also ask for help on: FreePBX Community Forums
Hi @RalphGraham
that's not a domain name.
Ah, now http://ralphgraham.org/ answers (earlier checked, timeout).
But what's that?
http://ralphgraham.org/.well-known/acme-challenge/1234
Not Found [CFN #0005]
Is this a freepbx answer? Or is it a USG answer?
First would be good (correct port forward). Second would be bad.
PS: Checked your domain via https://check-your-website.server-daten.de/?q=ralphgraham.org#ct-logs
There is no older certificate.
Looks like it's your first certificate you want to create.
PPS: Ah - crt.sh | ralphgraham.org - only subdomains, that's the reason.
grahome.ralphgraham.org has older certificates.
Checked your subdomain - https://check-your-website.server-daten.de/?q=grahome.ralphgraham.org - there you see the problem.
• http://grahome.ralphgraham.org/ 213.123.199.240 -14 10.014 T
Timeout - The operation has timed out
• http://www.grahome.ralphgraham.org/ 64.98.145.30 No GZip used - 3257 / 5945 - 54,79 % possible 200 Html is minified: 107,47 % 0.216 H
small visible content (num chars: 203)
ralphgraham.org is a totally awesome idea still being worked on. Check back later. Home Transfer Renew Domain Pricing Email About Us Help Your Account Copyright © 2021 Hover Terms of Service Privacy
Your www version isn't relevant, that's a message from your hoster.
But your non-www has a timeout.
So you main domain has the correct answer, your subdomain has a wrong configuration.
A http status 200 or 404 (/.well-known/acme-challenge/random-filename) is expected.
He already did it :wink:
Here is details
Certificate Alternative Names
DNS:grahome.ralphgraham.org
Certificate Valid Until
2021-02-18 (25 days)
That is what I am trying to update
Many thanks
Someone on freepbx community has suggested moving to dns-1 but does not say how to do that, any suggestions please?
You have to fix the timeout. Then you can use http validation.
Compare your main domain and your subdomain. First works, second not.
Sorry to be ignorant but I need more detail for your last response.
Are you saying to have certificate for grahome.ralphgraham.org I need also a certificate for the main domain as well?
How do I fix timeout and how do I use http validation?
Many thanks
