Issue with renewing certificate
Hello Let's Encrypt community,
I have following issue with my certificate. I want to renew the expiring certificate, but i get an authorized failure.
    Domain: www.cloud.companyname.de
    Detail: Incorrect validation certificate for tls-sni-01 challenge.
    Requested
    a8c63a9f369517e86bf88ab1ea36362a.a5c3668f10e0f04be17da90aa0dd3ff6.acme.invalid
    from ipaddress:443. Received 2 certificate(s), first
    certificate had names "cloud.companyname.de, www.cloud.companyname.de"
    Domain: cloud.companyname.de
    Requested
    51825fce4bc81a79399e9daf4bd60843.76da8bb98019bd71767b4281ccbf3a22.acme.invalid
I didn't change anything in the config file after creating the first certificate. But where is the problem. Thanks in advance!
Regards,
Maxi
Hi @Maxi
your domain is www.cloud.meyer.de . But I can't find an older certificate.
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:true;include_subdomains:true;domain:cloud.meyer.de&lu=cert_search
tls-sni-01 is deprecated and can't used with new domain names.
So switch to http-01 - or dns-01 - validation.
So
Hello @JuergenAuer
How can I switch to http-01 - or dns-01 - validation on Linux?
Regards,
Maxi
You could run certbot --renew --preferred-challenge http (however that would effective override all renewals on your server, so proceed with caution)
Thank you
Thank you, it worked!
Regards,
Maxi
