Renew error: Incorrect validation certificate for tls-sni-01 challenge. Received 2 certificate(s), first certificate had names "biszumbitterenen.de"
biszumbitterenen.de
certbot -q renew
–force-renewal
–tls-sni-01-port=8888
Incorrect validation certificate for tls-sni-01 challenge. Requested fc5f879919219332cd8395e363622cfa.23d9092c0b3cfa776c5728418bce4822.acme.invalid from 78.94.230.158:443. Received 2 certificate(s), first certificate had names “biszumbitterenen.de
HA-Proxy version 1.7.9 2017/08/18
Alpine Linux 3.7
n/a
n/a
I want to renew any of my domains, e.g. www.biszumbitterenen.de, mail.biszumbitterenen.de.
Every single domain has an DNS A/AAAA record pointing to the same IP.
I have only 1 static IP and therefore I use a reverse proxy (HAProxy) to access any subdomain.
I was not expecting an error with renew considering this setup because creation finished w/o errors.
Any advice for solving this error is appreciated.
THX
This tells Certbot to answer the TLS-SNI challenge on port 8888, but Let's Encrypt will try to validate that challenge on port 443, so the validation will fail. You should remove this flag. That may result in a permission denied error if HAProxy is already listening on that port. There are various options to address that, but while you're here you should read this: What you need to know about TLS-SNI validation issues.
My recommendation is that as long as your spending some time updating your config, you should update it to work with the HTTP-01 or DNS-01 challenge.
Im using the same option when creating certificates.
I don’t understand why this fails when renewing certificates.
There’s a good guide explaining this.
Unfortunately the section of the guide regarding renewal seems to be inaccurate.
If you obtained the certificates originally using this guide, then I think you should be able to renew them with something like
certbot renew --preferred-challenges http-01
I also don’t agree with the suggestion to use --force-renewal and only run once a month. The more usual process of running certbot renew twice a day is intended to allow the automated renewals to recover from any temporary failures.
However, if you want to do that, I’d recommend a few other changes as well.
I would create a script like the following and make it executable:
#!/usr/bin/env bash
# Concatenate cert and key to the specified file:
(umask 077; cat "$RENEWED_LINEAGE/fullchain.pem" "$RENEWED_LINEAGE/privkey.pem" > "$1")
# Reload  HAProxy
service haproxy reload
Let’s say you save that as /usr/local/bin/haproxy-deploy.sh. Then run the certbot certonly command again to renew each certificate individually and change its renewal parameters:
sudo certbot certonly --standalone -d example.com \
  --preferred-challenges http-01 --http-01-port=8888 \
  --deploy-hook "/usr/local/bin/haproxy-deploy.sh /etc/ssl/example.com/example.com.pem"
replacing the path to the pem file with the one you’re actually using in haproxy.
Once you’ve successfully renewed your certs once with that command, a simple certbot renew should suffice in the future, and you can safely let certbot’s default twice-daily cron job or systemd timer handle it.
