Issue with renewing certificate
I wanna use a staging environment to check before using production.
i have done SSL with command: certbot certonly --webroot --agree-tos --email myemail@gmail.com -d mydomain -w /var/www/mydomain/
However, when I check the test environment to renew the certificate with the command: certbot renew -d mydomain --dry-run. I received a notification below: I don't know certainly that this above command is true or false because I search on the internet, most people show a congratulations notification unlike me.
My notification:
Currently, the renew verb is capable of either renewing all installed certificates that are due to be renewed or renewing a single certificate specified by its name. If you would like to renew specific certificates by their domains, use the certonly command instead. The renew verb may provide other options for selecting certificates to renew in the future.
May everybody help me to understand this notification?
Thankssss
Hi @diepgiahung096, and welcome to the LE community forum :slight_smile:
Please try:
certbot renew --dry-run
Side note: The original command shown with webroot is out of order: All the webroot parts need to come before the domain is declared.
Should be more like:
certbot certonly --agree-tos --email myemail@gmail.com --webroot -w /var/www/mydomain/ -d mydomain
when I check the certificate that still works.
app@nginx:~$ sudo certbot certificates
sudo: unable to resolve host nginx: Name or service not known
[sudo] password for app:
Found the following certs:
Certificate Name: mydomain
Domains: mydomain
Expiry Date: 2021-10-13 17:18:56+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/mydomain/fullchain.pem
Private Key Path: /etc/letsencrypt/live/mydomain.vn/privkey.pem
i have tried certbot renew --dry-run, however, it failed, I received a notification like this
app@nginx:~$ sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/mydomain.conf
http-01 challenge for mydomain
Using the webroot path /var/www/mydomain for all unmatched domains.
Challenge failed for domain mydomain http-01 challenge for mydomain
Attempting to renew cert (mydomain) from /etc/letsencrypt/renewal/mydomain.conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/mydomain/fullchain.pem (failure)
    Domain: mydomain
    Type: connection
    Detail: Fetching
    https:mydomain/.well-known/acme-challenge/FXRHZOfySMKKSg767849V6E2nu2t6gTV75o8Z47sQLQ:
    Invalid empty hostname in redirect target
Check your configs and ensure the webroot being used by certbot is the same one being served by nginx for that domain.
Also pay close attention to the redirection and the nginx HTTPS config.
i have some question so may you help me to explain them ?.
I read information on the internet and i wonder that using certbot renew --dry-run command is only to check what is wrong certification or right certificate. If it is right i will use certbot renew command to renew my cert that is about to expire.
certbot renew --dry-run is to check if certificates can be renewed.
If any renewal was not possible, it should show entries in the logs as to any reason(s) for such failure(s).
certbot renew is the correct command to renew expiring certs.
It should be run on a schedule at least once a day - recommended twice a day.
Most of the time it will just check but have nothing to do; while certs are not nearing their expirations.
thank you so much.
