Issue with certificates on multiple ISPs
lediligent.com
Wordpress
Ubuntu 20.04 LTS
Scaleway
Hello,
Here is my issue
I run a Wordpress blog on a virtual machine in Scaleway, which I completely manage.
I configured the Let's encrypt certificate for www.lediligent.com years ago, as well as autorenew, and it works.
However, I'm using an ISP for the email server and a subsite conseil.lediligent.com.
It's a hosted service, I don't have access to the server, just a cpanel.
Everything worked fine until it switched from ordering certificates to Lets encypt.
Now I get the error message:
Unable to renew certificate: Updating challenge for conseil.lediligent.com: acme: error code 403 "urn:ietf:params:acme:error:unauthorized": 109.234.161.86: Invalid response from http://conseil.lediligent.com/.well-known/acme-challenge/Bp4jV42WwLetipI9-NAxm2scorgaLSKtzgfO0O-SdRM: 404 (order URL: https://acme-v02.api.letsencrypt.org/acme/order/60047711/83707586617)
How can I resolve the issue?
Should I generate the SSL certificates on my scaleway server and somehow import them into the other ISP's cpanel ?
Or should I generate them with the cpanel and how can I avoid the error message?
Thanks
I just see an error page there. There's probably some issue with the config of that server.
Is your ISP trying to strongarm you into buying a TLS certificate from them?
A1: That will depend on the amount of access you have to the server
A2: They are two different IPs - going that route would overcomplicate the cert process.
A3: If that is an available option then take it.
A4: See A1 and which message you are referring to (I see two: 403 and 404)
Thank you for your help!
In the end, the issue was with the hoster, which at some point switched my server without informing me, and the wrong IP address in the DNS.
All is well now.
