Issue with certificate
So the issue is this I had my server accesible at:
http://mdbserver.ddns.net
and I could access my owncloud instance. But I wanted to have an https certificate for security.
However after running lets encrypt it now times out in the browser and I get the below error code when I try to verify it. Even if I just use the normal http which worked before. Any ideas?
mdbserver.ddns.net
Used Let’s encrypt from dietpi menu.
Error code 1:
An unexpected error occurred:
Error creating new order :: Cannot issue for “mdbserver.ddns.net/owncloud”: Domain name contains an invalid character
lighttpd/1.4.53 (ssl)
Dietpi - Latest version : v6.31.2
no-ip
Yes
Unsure of this answer
More of the output
2020-08-01 15:38:44,541:DEBUG:certbot.main:certbot version: 0.31.0
2020-08-01 15:38:44,541:DEBUG:certbot.main:Arguments: [’–webroot’, ‘-w’, ‘/var/www’, ‘–agree-tos’ 2020-08-01 15:38:44,544:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#man
2020-08-01 15:38:44,566:DEBUG:certbot.log:Root logging level set at 20
2020-08-01 15:38:44,567:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-08-01 15:38:44,569:DEBUG:certbot.plugins.selection:Requested authenticator webroot and install$
2020-08-01 15:38:44,569:DEBUG:certbot.plugins.selection:Single candidate plugin: * webroot
Description: Place files in webroot directory
Entry point: webroot = certbot.plugins.webroot:Authenticator
Initialized: <certbot.plugins.webroot.Authenticator object at 0xb57c7a70>
Prep: True
2020-08-01 15:38:44,570:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.web$
2020-08-01 15:38:44,570:INFO:certbot.plugins.selection:Plugins selected: Authenticator webroot, Ins$
2020-08-01 15:38:44,589:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(body=Regis$
2020-08-01 15:38:44,591:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.o$
2020-08-01 15:38:44,595:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.ap$
2020-08-01 15:38:45,168:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET $
2020-08-01 15:38:45,169:DEBUG:acme.client:Received response:
HTTP 200
Well, Let's Encrypt only issues certificates for pure FQDNs, not for URIs. Your """hostname""" contains the path /owncloud which obviously is part of an URI and not part of the FQDN. You should try to issue a certificate for just mdbserver.ddns.net without the path part. How this is achieved through the DietPi menu? I don't know, could even be a buggy implementation from DietPi's part.
Also, the reason why your Owncloud is "down" is because a redirect from HTTP to HTTPS is in effect, probably installed after you succesfully got a certificate issued yesterday. It seems your port 443 — required for "basic" HTTPS (without specifying a non-standard port) — isn't open. Could be a NAT router without the proper portmap or a firewall which has port 443 closed.
It was my firewall setup and all is running well now.
Initially I thought it was because I hadn’t included /owncloud/ but it was my own idiocy.
Thanks for your help @Osiris
