Hi i am using Kerio connect. There is a point where i make Lets Encypt Cert. and it updates the cert. automaticly. But since yesterday it stopped working. If i want to make a new Cert i get the msg: https://acme-v02.api.letsencrypt.org/directory;rel="index" to read a header,couln't resolve host name.
hostname mail.met-architects.com is working and the port 80 is open.
does anybody knows the problem?
This suggests DNS might be failing on your system.
I don't see any DNS issue with the ACME API endpoint: acme-v02.api.letsencrypt.org | DNSViz (those 2 warnings are not important). Thus it seems to be an issue with your host.
As far as I know, nothing has changed in the way the Let's Encrypt ACME API DNS work. It's DNS service is Cloudflare for a very long time and has not seen a recent change.
Or maybe the screenshot is incorrect? I'm very curious what, in their eyes, was changed by Let's Encrypt and what the change to Keiro Connect exactly is.
The only thing that has changed recently were the intermediates used to sign the end leaf certificates, but that doesn't have any impact on the DNS? Weird..
