My domain is: miljopalatset.se
I ran this command: sudo ee site update www.domän.se --letsencrypt=on
It produced this output: Connection error
My web server is (include version): Linode
The operating system my web server runs on is (include version): Ubuntu 16.04 LTS Linux, Nginx
www.miljopalatset.se and miljopalatset.se point to different IP addresses and are hosted by different providers. If you’re running your ee command on the www.miljopalatset.se server, it will have no effect on the other one because it’s a physically separate server.
If you reconcile this somehow, then you should be able to get things to work.
In either case, it may be necessary to get the hosting provider’s cooperation to ensure that inbound port 443 connections are not blocked by a firewall.
I have got a respond for their agency that handles their domains and I have attached an image saying that both www and without is pointing to the correct IP?
