My Domain name is test.asyncwq.cognizant.com
When i am trying to create Certificate I am getting the below error. CAn you please help me with the below error.
Installing Python packages…
Installation succeeded.
An unexpected error occurred:
ValueError: error:060800A3:digital envelope routines:EVP_DigestInit_ex:disabled for fips
- sudo sed -i -e ‘s|hashlib.md5|hashlib.sha256|’ /opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/account.py
- sudo WQ_DOMAIN=test.asyncwq.cognizant.com scl enable python27 '/appl/letsencrypt/certbot-auto certonly --standalone -d test.asyncwq.cognizant.com -m wealthquay@cognizant.com --agree-tos ’
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let’s Encrypt project and the non-profit
organization that develops Certbot? We’d like to send you email about EFF and
our work to encrypt the web, protect its users and defend digital rights.
(Y)es/(N)o: (Y)es/(N)o: (Y)es/(N)o: (Y)es/(N)o: Yes
ValueError: Extra data: line 1 column 77 - line 38 column 1 (char 76 - 1828)
- ‘[’ ‘!’ -z vsftpd ‘]’
- sudo service vsftpd start
Redirecting to /bin/systemctl start vsftpd.service - [[ vsftpd == \h\t\t\p\d\2\4-\h\t\t\p\d.\s\e\r\v\i\c\e ]]
- sudo scl enable python27 ‘/appl/letsencrypt/certbot-auto renew --pre-hook ‘’‘systemctl stop vsftpd’’’ --post-hook ‘’‘systemctl start vsftpd’’’ --dry-run’
No renewals were attempted.
No hooks were run.
- echo ‘Setup for Crontab job of certificate renewal started…’
Setup for Crontab job of certificate renewal started… - sudo grep -q 'wq-vsftpd-renew-certs.sh ’ /var/spool/cron/root
- sudo tee -a /var/spool/cron/root
- echo ‘00 00 * * * python -c ‘’‘import random; import time; time.sleep(random.random() * 3600)’’’ && /appl/letsencrypt/wq-vsftpd-renew-certs.sh’
00 00 * * * python -c ‘import random; import time; time.sleep(random.random() * 3600)’ && /appl/letsencrypt/wq-vsftpd-renew-certs.sh - echo ‘Setup for Crontab job of certificate renewal completed’
[root@wqtest05 letsencrypt]#
Lets Encrypt Error:
2018-04-12 12:05:49,715:DEBUG:certbot.log:Exiting abnormally:
File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 11, in
sys.exit(main())
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/main.py”, line 1266, in main
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/main.py”, line 1141, in certonly
le_client = _init_le_client(config, auth, installer)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/main.py”, line 635, in _init_le_client
acc, acme = _determine_account(config)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/main.py”, line 514, in _determine_account
config, account_storage, tos_cb=_tos_cb)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/client.py”, line 172, in register
eff.handle_subscription(config)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/eff.py”, line 30, in handle_subscription
subscribe(config.email)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/eff.py”, line 61, in subscribe
_check_response(requests.post(url, data=data))
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/eff.py”, line 75, in _check_response
if not response.json()[‘status’]:
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/requests/models.py”, line 833, in json
self.content.decode(encoding), **kwargs
File “/opt/rh/python27/root/usr/lib64/python2.7/json/init.py”, line 339, in loads
return _default_decoder.decode(s)
File “/opt/rh/python27/root/usr/lib64/python2.7/json/decoder.py”, line 367, in decode
raise ValueError(errmsg(“Extra data”, s, end, len(s)))
2018-04-12 12:05:49,720:ERROR:certbot.log:An unexpected error occurred:
