Issue 2 certificates for 2 different sites using same domain (different subdomains) fails!
I have 2 wordpress sites that share same subdomains:
Site1 (/var/www/sites/greenfrogroofing):
innerwest.greenfrogroofing.com.au
Site2 (/var/www/sites/greenfrogroofing1 - not same folder as above) :
www.greenfrogroofing.com.au
Problem
While I successfully issued a certificate for Site1’s innerwest.greenfrogroofing.com.au domain using http-01 challenge, I am unabled to generate certificate for the 2nd site. I get the following error after running
sudo /opt/letsencrypt/certbot-auto --debug --email admin@example.com --no-eff-email --agree-tos -n --nginx --no-redirect --keep --expand -d greenfrogroofing.com.au -d www.greenfrogroofing.com.au certonly --dry-run
Output
http-01 challenge for greenfrogroofing.com.au
http-01 challenge for www.greenfrogroofing.com.au
   Domain: www.greenfrogroofing.com.au
   Type:   unauthorized
   Detail: Invalid response from
   http://www.greenfrogroofing.com.au/.well-known/acme-challenge/_rioMweHnrnRWTUIhV-WR7AgW-1YSIYjq9-XWJARYRQ:
   "<!DOCTYPE html>
   <html lang="en">
       <head>
           <meta charset="utf-8">
           <meta http-equiv="X-UA-Compatible" conten"
I verified the following issues:
  1. No https redirection. I even manually added a file under .well-known/acme-challenge/myfile.txt and successfully read it using http.
The curl output is this:
> curl -i http://www.greenfrogroofing.com.au/.well-known/acme-challenge/myfile.txt
HTTP/1.1 200 OK
Server: nginx
Date: Sun, 22 Apr 2018 08:19:19 GMT
Content-Type: text/plain
Content-Length: 0
Last-Modified: Wed, 18 Apr 2018 16:00:07 GMT
ETag: "5ad76b87-0"
X-UA-Compatible: IE=Edge
X-Rocket-Nginx-Serving-Static: No
Accept-Ranges: bytes
  1. There is no permission issues. I ran certbot with root command and I even went too far t o give .well-known 777 access but that didn’t help.
NOTES
I tried to install other sites on the server that has different domain (not greenfrogroofing.com.au) but and all works perfectly.
I believe this has something to do with already having a certificate for Site1 that shares same domain (but both sites have different folders and different conf files!)
CONF FILES
Site1:
      listen 80;
      server_name innerwest.greenfrogroofing.com.au
      root /var/www/sites/greenfrogroofing;
          index index.php;
          try_files $uri $uri/ /index.php?q=$uri&$args;
      location ~ \.php$ {
          fastcgi_pass unix:/var/run/php-fpm/php-fpm.sock;
          fastcgi_index index.php;
          fastcgi_param SCRIPT_FILENAME  $document_root$fastcgi_script_name;
          include fastcgi_params;
      include elemento.conf;
      include h5bp/basic.conf;
      include wp-rocket.conf;
      include wordpress-security.conf;
      access_log /var/log/nginx/greenfrogroofing.access.log;
      error_log /var/log/nginx/greenfrogroofing.error.log;
      ssl_certificate /etc/letsencrypt/live/innerwest.greenfrogroofing.com.au/fullchain.pem; # managed by Certbot
      ssl_certificate_key /etc/letsencrypt/live/innerwest.greenfrogroofing.com.au/privkey.pem; # managed by Certbot
Site 2:
    listen 80;
    server_name www.greenfrogroofing.com.au greenfrogroofing.com.au;
    root /var/www/sites/greenfrogroofing1;
        index index.php;
    location ~ \.php$ {
    access_log /var/log/nginx/greenfrogroofing1.access.log;
    error_log /var/log/nginx/greenfrogroofing1.error.log;
Your IPv6 and IPv4 addresses for that domain appear to point to completely different hosting services.
Either update your AAAA record to the IPv6 address of your new hosting, or withdraw the AAAA record entirely.
$ curl -X GET -I -6 www.greenfrogroofing.com.au/.well-known/acme-challenge/myfile.txt
HTTP/1.1 404 Not Found
Expires: Wed, 11 Jan 1984 05:00:00 GMT
Cache-Control: no-cache, must-revalidate, max-age=0
Link: <http://www.greenfrogroofing.com.au/wp-json/>; rel="https://api.w.org/"
Transfer-Encoding: chunked
Date: Sun, 22 Apr 2018 08:57:34 GMT
Server: LiteSpeed
Connection: Keep-Alive
$ curl -X GET -I -4 www.greenfrogroofing.com.au/.well-known/acme-challenge/myfile.txt
Server: nginx
Date: Sun, 22 Apr 2018 08:57:46 GMT
Content-Length: 162
Thanks! It solved it.
