Domain A, with Rating A, is gp-staging.mahlzeit.systems, Domain B, with rating T, is gpapi-staging.mahlzeit.systems.
This is the Output when i run the certbot-auto Script:
./certbot-auto
Requesting to rerun ./certbot-auto with root privileges...
[sudo] password for myadmin:
1: jalaxi.han-solo.net
2: gp-staging.mahlzeit.systems
3: gpapi-staging.mahlzeit.systems
blank to select all options shown (Enter 'c' to cancel): 2
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/gp-staging.mahlzeit.systems.conf)
What would you like to do?
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/gpapi-staging-le-ssl.conf
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Redirecting vhost in /etc/apache2/sites-enabled/gpapi-staging.conf to ssl vhost in /etc/apache2/sites-enabled/gpapi-staging-le-ssl.conf
Congratulations! You have successfully enabled
https://gp-staging.mahlzeit.systems
https://www.ssllabs.com/ssltest/analyze.html?d=gp-staging.mahlzeit.systems
/etc/letsencrypt/live/gp-staging.mahlzeit.systems/fullchain.pem
/etc/letsencrypt/live/gp-staging.mahlzeit.systems/privkey.pem
Your cert will expire on 2018-11-28. To obtain a new or tweaked
version of this certificate in the future, simply run certbot-auto
again with the "certonly" option. To non-interactively renew *all*
of your certificates, run "certbot-auto renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
And this by Domain B:
./certbot-auto
blank to select all options shown (Enter 'c' to cancel): 3
(ref: /etc/letsencrypt/renewal/gpapi-staging.mahlzeit.systems.conf)
Enhancement redirect was already set.
https://gpapi-staging.mahlzeit.systems
https://www.ssllabs.com/ssltest/analyze.html?d=gpapi-staging.mahlzeit.systems
/etc/letsencrypt/live/gpapi-staging.mahlzeit.systems/fullchain.pem
/etc/letsencrypt/live/gpapi-staging.mahlzeit.systems/privkey.pem
This are the config file:
<VirtualHost 83.138.87.139:80>
ServerAdmin webmaster@gpapi-staging.mahlzeit.systems
DocumentRoot /var/www/gpapi-staging.mahlzeit.systems/current/public
ServerName gpapi-staging.mahlzeit.systems
ServerAlias gpapi-staging.mahlzeit.systems
ErrorLog /var/www/gpapi-staging.mahlzeit.systems/current/storage/logs/error.log
CustomLog /var/www/gpapi-staging.mahlzeit.systems/current/storage/logs/access.log common
#RewriteEngine on
#RewriteCond %{SERVER_NAME} =gpapi-staging.mahlzeit.systems
#RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
RewriteEngine on
</VirtualHost>
ServerAdmin webmaster@gp-staging.mahlzeit.systems
DocumentRoot /var/www/gp-staging.mahlzeit.systems/public
ServerName gp-staging.mahlzeit.systems
ServerAlias gp-staging.mahlzeit.systems
ErrorLog /var/www/gp-staging.mahlzeit.systems/logs/error.log
CustomLog /var/www/gp-staging.mahlzeit.systems/logs/access.log common
#RewriteEngine on
#RewriteCond %{SERVER_NAME} =gp-staging.mahlzeit.systems
RewriteEngine on
</VirtualHost>
And this is the ssl config file:
<IfModule mod_ssl.c>
<VirtualHost 83.138.87.139:443>
SSLCertificateFile /etc/letsencrypt/live/gp-staging.mahlzeit.systems/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/gp-staging.mahlzeit.systems/privkey.pem
</VirtualHost>
</IfModule>
SSLCertificateFile /etc/letsencrypt/live/gpapi-staging.mahlzeit.systems/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/gpapi-staging.mahlzeit.systems/privkey.pem
</VirtualHost>
</IfModule>
