Is there a way to manually reset the SSL certificate?
My domain is:uaysk.com
I ran this command:really simple ssl
It produced this output:Invalid response received for request (POST https://acme-v02.api.letsencrypt.org/acme/new-order): rate limit reached - Error creating new order :: too many certificates (5) already issued for this exa
My web server is (include version):apache2.4, php8.0
The operating system my web server runs on is (include version):debian 11
My hosting provider, if applicable, is:none
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):aapanel
I had initialized the site several times due to file permission problems, and in the process, I also requested ssl certificate several times through really simple ssl
After the error occurred, I tried to authenticate again after Sunday, but that error still occurs
Hi @uaysk0327 and welcome to the LE community forum :slight_smile:
Only time can overcome that rate limit.
Is there any way to use one of the five certs already issued?
The WordPress plugin I'm using doesn't seem to provide a separate feature for entering SSL certificate information.
I checked crt.sh | uaysk.com and found that the date of requesting the certificate was issued on the 14th. If so, will the restriction be lifted from the 21st?
