I lost my SSL after I deleted my website a few times to fix upload on wordpress
My domain is: https://condominiocesarbarretto.com.br/
I ran this command: issue SSL on cyberpanel
My web server is (include version): cyberpanel 2.1
The operating system my web server runs on is (include version): linux 20 LTS
My hosting provider, if applicable, is: digital ocean
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes
Hi @Jairo,
it seems* you have exceeded Duplicate Certificate rate limit (you can read about rate limits here: Rate Limits - Let's Encrypt). Each time you've deleted and recreated your website, a new certificate was generated for your domains. You are limited to 5 identical certificates per week, as each certificate issued consumes some Let's Encrypt resources (deleting/revoking certificate does not reset this limit, because resources have already been consumed). You would be able to create new certificate when 7 days since issuance of first certificate for your domain have passed.
Let's Encrypt returns too many certificates already issued for exact set of domains message in such case, but it is possible that cyberpanel (I'm not familiar with it) is hiding that error message from you.
* There are 5 certificates for your domain visible in Certificate Transparency logs: crt.sh | condominiocesarbarretto.com.br
thanks for fast reply, can you tell me what can be done ? i have to wait 7 days ?
also idk how but the same problem happens on the other website i have called luxoemsalvador.com.br but im sure i dint make new certificates or change this one.
i tryed change my SSL to cloudflare but idk if take time to work or if i did it wrong
how i know what is going on with my SSL ?
omg why those things always happens in the worst time possible. my client has 3 days to make a sell and im stuck with a fucking certificcated. in last case im considering buy a certificate but i never buyed 1.
