Is it possible to unblock site from SSL requests?
My domain is: https://www.futuregroup-build.com
Tried to setup SSL on Siteground
ERROR: acmebot->create_new_order: Net::ACME2::x::ACME: Ć¢Ā€Āœhttps://acme-v02.api.letsencrypt.org/acme/new-orderĆ¢Ā€Ā indicated an ACME error: 429 Too Many Requests (429 urn:ietf:params:acme:error:rateLimited (The request exceeds a rate limit) (Error creating new order :: too many certificates already issued for exact set of domains: futuregroup-build.com,www.futuregroup-build.com: see https://letsencrypt.org/docs/rate-limits/)). ==> Net::ACME2::x::Generic::new(ā€˜Net::ACME2::x::ACME’, 'Ć¢Ā€Āœhttps://acme-
Unsure, siteground hosting
Siteground
No
Yes siteground
Unable to do
This is my friend website - he got hacked (maybe this is why the repeat certificates), he has fixed the malware issues now but the website is not SSL anymore. Siteground says he just had to wait 7 days but it’s causing some issues for him so I thought I’d ask on here for him if it was possible t
Sorry, no.
You can not request temporary rate limit requests.
No problem @stevenzhu thanks for the quick reply. Appreciate all that you guys do over here. I’ll suggest to him he pays for the premium SSL solution with siteground or waits the 7 days.
If your friend has already created 5 certificates, why not use one of them?
Good point there, I’m not sure he has access to them as he did it via Siteground. There’s no SSL certificates available in his Siteground SSL manager panel. I’ll tell him to ask Siteground if they have any of the SSLs available too.
It’s possible he didn’t create them, the malware did, but I don’t know, I will ask him and make sure. Thank you for the contribution @JimPas!:slight_smile:
Siteground generally create these certificates automatically...
So it might be possible they still hold a copy of that certificate.
P.S. You can also ask him to apply for a trial certificate at any CA (the ones without the need of credit card) and replace it with Let's Encrypt certificate once the rate limit is over.
