I just wanted to try certbot to reinsatlliren and here comes an error out can be there something
Please show:
ls -l /usr/bin/certbot
What shows?:
/usr/bin/certbot --version
And what shows?:
certbot --version
and if i want to go to http://portainer.the-dodo.de/
this is not working only if i have the vpn on there is also a problem
well with portainer it is not bad but with other sites
Step 6 failed because a previous step was skipped.
You still have version 1.21.0 installed.
What shows?:
snap list
So, you do have two versions of certbot
installed.
That means...
You skipped the step where you uninstall the older version.
now I have only 2.5.0 and still does not work
logs in docker nginxproxymanager
Container
[5/5/2023] [7:00:25 PM] [Nginx ] › ⬤ debug Deleting file: /data/nginx/proxy_host/2.conf
[5/5/2023] [7:00:25 PM] [Nginx ] › ⬤ debug Deleting file: /data/nginx/proxy_host/2.conf.err
[5/5/2023] [7:00:25 PM] [Nginx ] › ⬤ debug Could not delete file: {
"errno": -2,
"syscall": "unlink",
"code": "ENOENT",
"path": "/data/nginx/proxy_host/2.conf.err"
[5/5/2023] [7:00:25 PM] [Nginx ] › ℹ info Reloading Nginx
[5/5/2023] [7:00:30 PM] [SSL ] › ℹ info Requesting Let'sEncrypt certificates for Cert #29: portainer.the-dodo.de
[5/5/2023] [7:00:30 PM] [SSL ] › ℹ info Command: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-29" --agree-tos --authenticator webroot --email "dominik261@outlook.de" --preferred-challenges "dns,http" --domains "portainer.the-dodo.de"
[5/5/2023] [7:00:33 PM] [Nginx ] › ⬤ debug Deleting file: /data/nginx/temp/letsencrypt_29.conf
[5/5/2023] [7:00:33 PM] [Nginx ] › ℹ info Reloading Nginx
[5/5/2023] [7:00:33 PM] [Express ] › ⚠ warning Command failed: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-29" --agree-tos --authenticator webroot --email "dominik261@outlook.de" --preferred-challenges "dns,http" --domains "portainer.the-dodo.de"
Saving debug log to /tmp/letsencrypt-log/letsencrypt.log
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/letsencrypt-log/letsencrypt.log or re-run Certbot with -v for more details.
What does this file show?:
Unfortunately
is not a very good piece of software
[especially when things go wrong and you are trying to troubleshoot and find exactly where a problem exists]
@rg305 you can also see here
What does that file contain?
Where?
Is that within the right container?
what do you mean ?
