[3/31/2025] [3:11:58 PM] [Nginx ] › ⬤ debug Could not delete file: {
"errno": -2,
"code": "ENOENT",
"syscall": "unlink",
"path": "/data/nginx/proxy_host/2.conf.err"
[3/31/2025] [3:11:58 PM] [Global ] › ⬤ debug CMD: /usr/sbin/nginx -t -g "error_log off;"
info Reloading Nginx
[3/31/2025] [3:11:58 PM] [Global ] › ⬤ debug CMD: /usr/sbin/nginx -s reload
[3/31/2025] [3:12:03 PM] [SSL ] ›
info Requesting Let'sEncrypt certificates for Cert #10: auto.tb.tec.br
info Command: certbot certonly --config '/etc/letsencrypt.ini' --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-10" --agree-tos --authenticator webroot --email 'iatudobelo@gmail.com' --preferred-challenges "dns,http" --domains "auto.tb.tec.br"
[3/31/2025] [3:12:03 PM] [Global ] › ⬤ debug CMD: certbot certonly --config '/etc/letsencrypt.ini' --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-10" --agree-tos --authenticator webroot --email 'iatudobelo@gmail.com' --preferred-challenges "dns,http" --domains "auto.tb.tec.br"
[3/31/2025] [3:13:36 PM] [Nginx ] › ⬤ debug Deleting file: /data/nginx/temp/letsencrypt_10.conf
[3/31/2025] [3:13:36 PM] [Global ] › ⬤ debug CMD: /usr/sbin/nginx -t -g "error_log off;"
[3/31/2025] [3:13:36 PM] [Global ] › ⬤ debug CMD: /usr/sbin/nginx -s reload
Express ] ›
warning Saving debug log to /tmp/letsencrypt-log/letsencrypt.log
my npm is not issuing a certificate and these are the logs it returns to me, can someone help me? and on the npm panel itself it gives an internal error
