Installing SSL on IONOS shared Hosting: is it possible?
My domain is: covidquiz.org
I’m not really a techie, so I can’t answer all those questions. Here’s what I do k ow:
My hosting provider is: IONOS France
My site runs on WORDPRESS.org
I might have SSH access via IONOS.
CPanel is not available on IONOS shared hosting
I used the Wordpress Plugin SSL Zen to downloaded the Lets Encrypt certificate files for my website. But I can not find a way to instal the certificate because IONOS does not have access to CPanel.
I tried installing the certificate via Filezilla Server. I followed the instructions online but I didn’t seem to be able to connect to the serve.
Maybe there is a way to do instal the certificate via PLESK? But honestly, I don’t really understand what PLESK is.
I have several small websites and 30 euros per year for each site to have SSL from IONOS seems pretty pricey.
I really want to find a way to get free HTTPS through Let’s Encrypt.
Thanks so much for any help.
Hi @worldbiking
nobody knows your configuration. Start with
If you use shared hosting, your options are limited.
If your hoster doesn't allow the installation of own certificates, you can't install a Letsencrypt certificate.
So ask Ionos.
