Hi, I'm following this thread : How to get a Let's Encrypt certificate while using CloudFlare
And here's what I exactly did:
1 - logged in using SSH via Putty.
2 - Cloned LE from git and change to LE directory as shown in the thread.
git clone GitHub - certbot/certbot: Certbot is EFF's tool to obtain certs from Let's Encrypt and (optionally) auto-enable HTTPS on your server. It can also act as a client for any other CA that uses the ACME protocol.
cd letsencrypt/
3 - automatic install of LE: ./letsencrypt-auto
Things started to be installed and I got the output:
installation succeeded.
No installers seem to be present and working on your system; fix that or try running Certbot with the Certonly command.
4 - I typed the command :certonly --webroot --webroot-path /usr/share/nginx/html/ --renew-by-default --email email@host.tld --text --agree-tos -d example.tld -d www.example.tld as said in the thread and with the necessary changes and I got Certonly command not found.
then I typed /root/.local/share/letsencrypt/bin/letsencrypt certonly --webroot --webroot-path /usr/share/nginx/html/ --renew-by-default --email email@host.tld --text --agree-tos -d example.tld -d www.example.tld and I got this long output:
2016-09-17 10:19:07,632:WARNING:certbot.cli:You are running with an old copy of letsencrypt-auto that does not receive updates, and is less reliable than more recent versions. We recommend upgrading to the latest certbot-auto script, or using native OS packages.
403 Forbidden
Failed authorization procedure. www.mysite.ltd (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.mysite.ltd/.well-known/acme-challenge/liqON_bL_7H4CqBHkyonznc5X0i0KiAKXCNq5vsV2RA: "403 Forbidden
ngin", mysite.ltd (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://mysite.ltd/.well-known/acme-challenge/fBhBJUcFoC5HlfvUnhGTrT0VYziIfja6oENehr_qdnc: " 403 Forbidden403 Forbidden
ngin"
- If you lose your account credentials, you can recover through
e-mails sent to email@live.com.- The following errors were reported by the server:
Domain: www.mysite.ltd
403 Forbidden
Detail: Invalid response from
http://www.mysite.ga/.well-known/acme-challenge/liqON_bL_7H4CqBHkyonznc5X0i0KiAKXCNq5vsV2RA:
"403 Forbidden
ngin"
Domain: mysite.ltd
403 Forbidden
"403 Forbidden
ngin"
Please I nedd help.
Thanks in advance.
any thoughts ??
