Installed Let's Encrypt SSL not showing HTTPS
My domain is: www.mca.ac.ug
I used instructions from this video https://www.youtube.com/watch?v=WqCk9dVLoPw
Successfully installed certificate but website still shows insecure on many browsers
Apache. Shared webhosting
NGINX
eUKhost LTD
NO
cPanel 76.0.18
Not Sure
did you install ssl chain ? fullchain,pem
There is a cert mismatch: https://www.ssllabs.com/ssltest/analyze.html?d=www.mca.ac.ug
[one site is using another sites’ cert]
you can try -d *.mca.ac.ug -d mca.ac.ug
Three things wrong with that:
  1. Always use quotes around asterisks; so: -d "*.mca.ac.ug" -d mca.ac.ug
  2. The mismatched cert is from a completely different domain ("milima.org"), so a wildcard cert won't change anything.
  3. Wildcard certs would require changing the authentication method to DNS.
I followed every instruction on that video so I can’t tell what went wrong. I also need to be honest, I am quite novice when it comes to SSL installations. Is there a site which offers step by step instructions on how to install SSL by Lets Encrypt for Wordpress website. Please note that I have no access to root but I have access to cPanel. Thanks again.
I’m not familiar with cPanel.
But I do see that your sites works without the “www”: https://www.ssllabs.com/ssltest/analyze.html?d=mca.ac.ug&latest
So, perhaps, you just need to include the www as an alias and get a new cert that contains both names: “mca.ac.ug” & “www.mca.ac.ug”
No need to put “” on wildcard domain . I didn’t see milima,org . just checked www.mca.ac.a=ug. :smiley:
Is there a site which would give me step by step instructions so that I don’t repeat the same mistakes. Also, how do I deal with the stray domain milima.org?
Please don't say that.
Even if it works on your system that will NOT work on all systems.
Hm . that is correct .
The Internet is full of information, so I guess yes there is.
But I don't use cPanel and don't know of any particular site.
That is not something you need to "fix".
It is a side effect of the web server looking for a name that it can't serve.
So it serves the first/default site that matches the type of request (https).
You "fix" it by providing cPanel a way to know where "www.mca.ac.ug" is.
