Let's Encrypt SSL Not Showing
My domain is: worldnews.gq
I ran this command: certbot certonly
1: Apache Web Server plugin - Beta (apache)
2: Place files in webroot directory (webroot)
3: Spin up a temporary webserver (standalone)
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 2
Please enter in your domain name(s) (comma and/or space separated)  (Enter 'c'
to cancel):worldnews.gq
http-01 challenge for worldnews.gq
Select the webroot for worldnews.gq:
1: Enter a new webroot
Press 1 [enter] to confirm the selection (press 'c' to cancel):
** Invalid input **
Press 1 [enter] to confirm the selection (press 'c' to cancel): 1
Input the webroot for worldnews.gq: (Enter 'c' to cancel):webroot
webroot does not exist or is not a directory
Input the webroot for worldnews.gq: (Enter 'c' to cancel):/opt/bitnami/apps/wordpress/htdocs/
Generating key (2048 bits): /etc/letsencrypt/keys/0000_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0000_csr-certbot.pem
 - Congratulations! Your certificate and chain have been saved at
   /etc/letsencrypt/live/worldnews.gq/fullchain.pem. Your cert will
   expire on 2017-09-01. To obtain a new or tweaked version of this
   certificate in the future, simply run certbot again. To
   non-interactively renew *all* of your certificates, run "certbot
   renew"
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
Server version: Apache/2.4.25 (Unix) Server built: May 18 2017 14:10:36
The operating system my web server runs on is (include version): Debain 8.8
Even though it has successfully installed on my server, yet the https version is not showing up.
https://worldnews.gq
hi @worldnews_gq
This one should have been fairly easy to diagnose :wink:
You are still using a self signed certificate
Possible causes are:
A) You did not update the apache configuration (or certbot didn’t)
B) The application you are using is ignoring the apache config
C) You didn’t restart the apache server after the certificate configs were updated
Andrei
This is your problem. Rather than typing "webroot", you need to enter the path to the root of your web server, like /var/www/html (or wherever you've configured it to be).
Let's Encrypt has not issued a certificate, because of the error above.
Hi @danb35,
If you check the entire log posted, after the webroot fail, he/she wrote the right webroot path :wink:
Indeed, a certificate was issued:
Cheers,
sahsanu
Hello,
Thank you for the information.
Can you please let me know how solve each cause you mentioned?
I’ve restarted apache, still, it’s same.
Ah, indeed--I didn't realize that this text box wasn't showing the whole output, and you had to scroll to see it. My bad.
You used the certonly command, which means it will only issue the certificate. You'll need to edit your Apache configuration to point to the new certificate and private key.
How to edit that? Please let me know. I’ll edit that.
These are text files within /etc/apache2 which configure which sites exist on your system and are served by Apache. They need to be edited with a text editor. They are documented at
https://httpd.apache.org/docs/2.2/configuring.html (for Apache 2.2)
https://httpd.apache.org/docs/current/configuring.html (for Apache 2.4)
You will probably need to create a new file in /etc/apache2/sites-available that defines a VirtualHost with HTTPS enabled (referred to by Apache as “SSL” even though that’s no longer the current name for the TLS technology) and that points to the key and chain files in /etc/letsencrypt/live. Then you can enable this file with a2ensite, which will create a symbolic link in /etc/apache2/sites-enabled pointing to the file you created.
I believe there are probably a lot of tutorials on the web for this.
The Apache documentation also gives examples
https://httpd.apache.org/docs/2.2/vhosts/examples.html (2.2)
https://httpd.apache.org/docs/current/vhosts/examples.html (2.4)
but none of the examples use HTTPS (!!!). :frowning:
However, they have a separate section on this topic.
https://httpd.apache.org/docs/2.2/ssl/ (2.2)
https://httpd.apache.org/docs/current/ssl/ (2.4)
The certonly command basically assumes that you know how to do this or have a tutorial that you’re already following. If you wanted Certbot to create this virtual host for you, it can often do so if you instead used certbot run or certbot --apache!
webroot works wonders on all my nginx and Let’s Encrypt configs.
Sure, but it doesn't install the certificate for you.
