Installed certificates successfully but the website has loading problem
My domain is: finance.gkp.pk
sudo apt-get update
sudo apt-get install software-properties-common
sudo add-apt-repository universe
sudo add-apt-repository ppa:certbot/certbot
sudo apt-get update
Ubuntu18.04.4 LTS
Codename: Bionic
The operating system my web server runs on is (include version): Ubuntu
No
Hi @imshehryar
there are some checks of your domain, created yesterday - https://check-your-website.server-daten.de/?q=finance.gkp.pk
You have created one good certificate with both domain names (non-www and www):
Let's Encrypt Authority X3 2020-03-09 2020-06-07 finance.gkp.pk, www.finance.gkp.pk - 2 entries duplicate nr. 1
Let's Encrypt Authority X3 2020-03-09 2020-06-07 finance.gkp.pk - 1 entries duplicate nr. 1
But your port 443 doesn't answer.
Is there a blocking firewall? Or is this
Host T IP-Address is auth. āˆ‘ Queries āˆ‘ Timeout
finance.gkp.pk A 175.107.63.149 Peshawar/Khyber Pakhtunkhwa/Pakistan (PK) - National Telecommunication Corporation Hostname: 175-107-63-149.reverse.ntc.net.pk yes 1 0
AAAA yes
www.finance.gkp.pk A 175.107.63.149 Peshawar/Khyber Pakhtunkhwa/Pakistan (PK) - National Telecommunication Corporation Hostname: 175-107-63-149.reverse.ntc.net.pk yes 1 0
AAAA yes
a home server, so a port forwarding is missing?
Thanks for the quick response…
My ufw status is as follows:
To Action From
Apache ALLOW Anywhere
22/tcp ALLOW Anywhere
80 ALLOW Anywhere
443 ALLOW Anywhere
Apache (v6) ALLOW Anywhere (v6)
22/tcp (v6) ALLOW Anywhere (v6)
80 (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
Works your https internal?
curl https://finance.gkp.pk/
from that machine?
It produces the following output:
curl: (51) SSL: no alternative certificate subject name matches target host name ā€˜finance.gkp.pk’
please guide me how to resolve this issue…thank you
What command did you run to obtain and install your certificates?
What was its output?
You can find out the command by running history | grep certbot
I don't think so, looks governmental.
sudo apt install python-certbot-apache
sudo certbot --apache -d finance.gkp.pk -d www.finance.gkp.pk
what does certbot certificates say?
What says
apachectl -S
It says:
Found the following certs:
Certificate Name: finance.gkp.pk
Domains: finance.gkp.pk
Expiry Date: 2020-06-08 16:12:19+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/finance.gkp.pk/fullchain.pem
Private Key Path: /etc/letsencrypt/live/finance.gkp.pk/privkey.pem
Certificate Name: www.finance.gkp.pk
Domains: www.finance.gkp.pk
Expiry Date: 2020-06-08 16:22:12+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.finance.gkp.pk/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.finance.gkp.pk/privkey.pem
Running apachectl -S outpus the following:
VirtualHost configuration:
*:443 finance.gkp.pk (/etc/apache2/sites-enabled/finance.gkp.pk-le-ssl.conf:2)
*:80 finance.gkp.pk (/etc/apache2/sites-enabled/finance.gkp.pk.conf:1)
ServerRoot: ā€œ/etc/apache2ā€
Main DocumentRoot: ā€œ/var/www/htmlā€
Main ErrorLog: ā€œ/var/log/apache2/error.logā€
PidFile: ā€œ/var/run/apache2/apache2.pidā€
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=ā€œwww-dataā€ id=33 not_used
Group: name=ā€œwww-dataā€ id=33 not_used
Got it working by adding entry for :
<VirtualHost *:443>
entry in /etc/apache2/sites-available/mydomain.conf and clearing browser cache…
