Installation Issue: RHEL 7- python-zope-interface deprecated
I am trying to install certbot with yum in RHEL7, but getting dependency problems!, I have enabled EPEL but unfortunately the required package "python-zope-interface" is deprecated in the recent version.(RHEL 7 Removed packages any workaround for this..?
Resolving Dependencies
--> Running transaction check
---> Package python-zope-component.noarch 1:4.1.0-1.el7 will be installed
--> Processing Dependency: python-zope-interface for package: 1:python-zope-component-4.1.0-1.el7.noarch
--> Finished Dependency Resolution
Error: Package: 1:python-zope-component-4.1.0-1.el7.noarch (epel)
Requires: python-zope-interface
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
installed through downloading rpms, before this I installed python libraries required and then had to give nodeps
rpm -ivh --nodeps certbot-0.9.3-1.el7.noarch.rpm
rpm -ivh --nodeps python2-certbot-0.9.3-1.el7.noarch.rpm
try pip install zope.event
certbot only needs the zope.event framework
Andrei
also pip install zope.interface
