shafer
August 1, 2017, 3:24pm
#1
I’m stuck.
Attempting to install certbot. When I get to the step “yum install cetbot-apache” I get
–> Finished Dependency Resolution
rhel-x86_64-server-7/group | 636 kB 00:00:00
Error: Package: python2-certbot-0.14.1-3.el7.noarch (epel)
Requires: python-zope-interface
Error: Package: 1:python-zope-component-4.1.0-3.el7.noarch (epel)
You could try using --skip-broken to work around the problem
** Found 2 pre-existing rpmdb problem(s), ‘yum check’ output follows:
ipa-common-4.4.0-14.el7_3.7.noarch has installed conflicts freeipa-common: ipa-common-4.4.0-14.el7_3.7.noarch
ipa-python-compat-4.4.0-14.el7_3.7.noarch has installed conflicts freeipa-python-compat: ipa-python-compat-4.4.0-14.el7_3.7.noarch
I attempted to work around this by using:
pip install zope.event
pip install zope.interface
pip install certbot==0.9.3
But, alas, when I attempt to start certbot I get:
certbot --apache
An unexpected error occurred:
AttributeError: ‘tuple’ object has no attribute 'add’
Please see the logfile ‘certbot.log’ for more details.
Help, please!
can you run pip freeze and let us know what version of certbot was installed
I think one of the versions had an issue with tuples.
Review here: Potential Issue with New Certbot and Argparse - AttributeError: 'tuple' object has no attribute 'add'
BTW: all i did was paste your error message in the search. In future that may save you some time on waiting for someone to reply.
Andrei
shafer
August 2, 2017, 12:15am
#3
pi freeze tells me
certbot==0.9.3
ah ok I should have read your code a bit more
You specified version 0.9.3 - is there a particular reason for this?
Current version is 0.16.0 – i would install using
pip install certbot
and let it get the latest version
Andrei
schoen
August 2, 2017, 12:33am
#5
For that matter, most people who are trying to do some kind of installation outside of their OS package manager would probably be better served by using certbot-auto
, an autoupdater created by the Certbot team that’s meant for people who don’t have a working up-to-date operating system package.
shafer
August 2, 2017, 1:50am
#6
So… ideally I’d like to get a package manager working, instead of working around it. I was able to resolve the “installed conflicts” with freeipa.
Great. So, now I attempt the yum install certbot-apache command.
#yum install certbot-apache
Loaded plugins: langpacks, product-id, rhnplugin, search-disabled-repos, subscription-manager
This system is receiving updates from RHN Classic or Red Hat Satellite.
Resolving Dependencies
–> Running transaction check
—> Package python2-certbot-apache.noarch 0:0.14.1-1.el7 will be installed
–> Processing Dependency: python2-certbot = 0.14.1 for package: python2-certbot-apache-0.14.1-1.el7.noarch
–> Processing Dependency: certbot = 0.14.1 for package: python2-certbot-apache-0.14.1-1.el7.noarch
–> Processing Dependency: mod_ssl for package: python2-certbot-apache-0.14.1-1.el7.noarch
—> Package certbot.noarch 0:0.14.1-3.el7 will be installed
–> Processing Dependency: /usr/sbin/semanage for package: certbot-0.14.1-3.el7.noarch
—> Package mod_ssl.x86_64 1:2.4.6-45.el7_3.4 will be installed
—> Package python2-certbot.noarch 0:0.14.1-3.el7 will be installed
–> Processing Dependency: python2-acme = 0.14.1 for package: python2-certbot-0.14.1-3.el7.noarch
–> Processing Dependency: python2-dialog >= 3.3.0 for package: python2-certbot-0.14.1-3.el7.noarch
–> Processing Dependency: python2-configargparse >= 0.10.0 for package: python2-certbot-0.14.1-3.el7.noarch
–> Processing Dependency: python2-future for package: python2-certbot-0.14.1-3.el7.noarch
–> Processing Dependency: python-zope-interface for package: python2-certbot-0.14.1-3.el7.noarch
–> Processing Dependency: python-zope-component for package: python2-certbot-0.14.1-3.el7.noarch
–> Processing Dependency: python-parsedatetime for package: python2-certbot-0.14.1-3.el7.noarch
–> Processing Dependency: python-mock for package: python2-certbot-0.14.1-3.el7.noarch
—> Package policycoreutils-python.x86_64 0:2.5-11.el7_3 will be installed
–> Processing Dependency: libsemanage-python >= 2.5-5 for package: policycoreutils-python-2.5-11.el7_3.x86_64
–> Processing Dependency: setools-libs >= 3.3.8-1 for package: policycoreutils-python-2.5-11.el7_3.x86_64
–> Processing Dependency: audit-libs-python >= 2.1.3-4 for package: policycoreutils-python-2.5-11.el7_3.x86_64
–> Processing Dependency: python-IPy for package: policycoreutils-python-2.5-11.el7_3.x86_64
–> Processing Dependency: libapol.so.4(VERS_4.0)(64bit) for package: policycoreutils-python-2.5-11.el7_3.x86_64
–> Processing Dependency: libqpol.so.1(VERS_1.4)(64bit) for package: policycoreutils-python-2.5-11.el7_3.x86_64
–> Processing Dependency: libqpol.so.1(VERS_1.2)(64bit) for package: policycoreutils-python-2.5-11.el7_3.x86_64
–> Processing Dependency: checkpolicy for package: policycoreutils-python-2.5-11.el7_3.x86_64
–> Processing Dependency: libapol.so.4()(64bit) for package: policycoreutils-python-2.5-11.el7_3.x86_64
–> Processing Dependency: libqpol.so.1()(64bit) for package: policycoreutils-python-2.5-11.el7_3.x86_64
—> Package python-parsedatetime.noarch 0:1.5-3.el7 will be installed
—> Package python-zope-component.noarch 1:4.1.0-3.el7 will be installed
–> Processing Dependency: python-zope-interface for package: 1:python-zope-component-4.1.0-3.el7.noarch
–> Processing Dependency: python-zope-event for package: 1:python-zope-component-4.1.0-3.el7.noarch
—> Package python2-acme.noarch 0:0.14.1-1.el7 will be installed
–> Processing Dependency: pytz for package: python2-acme-0.14.1-1.el7.noarch
–> Processing Dependency: python-pyrfc3339 for package: python2-acme-0.14.1-1.el7.noarch
–> Processing Dependency: python-ndg_httpsclient for package: python2-acme-0.14.1-1.el7.noarch
—> Package python2-configargparse.noarch 0:0.11.0-1.el7 will be installed
—> Package python2-dialog.noarch 0:3.3.0-6.el7 will be installed
–> Processing Dependency: dialog for package: python2-dialog-3.3.0-6.el7.noarch
—> Package python2-future.noarch 0:0.16.0-2.el7 will be installed
—> Package python2-mock.noarch 0:1.0.1-9.el7 will be installed
—> Package audit-libs-python.x86_64 0:2.6.5-3.el7_3.1 will be installed
—> Package checkpolicy.x86_64 0:2.5-4.el7 will be installed
—> Package dialog.x86_64 0:1.2-4.20130523.el7 will be installed
—> Package libsemanage-python.x86_64 0:2.5-5.1.el7_3 will be installed
—> Package python-IPy.noarch 0:0.75-6.el7 will be installed
—> Package python-ndg_httpsclient.noarch 0:0.3.2-1.el7 will be installed
—> Package python-zope-event.noarch 0:4.0.3-2.el7 will be installed
—> Package python2-pyrfc3339.noarch 0:1.0-2.el7 will be installed
—> Package pytz.noarch 0:2012d-5.el7 will be installed
—> Package setools-libs.x86_64 0:3.3.8-1.1.el7 will be installed
You could try running: rpm -Va --nofiles --nodigest
I tried to overcome the zope-interface issue with the pip commands.
OK… I attempt to start certbot --apache and now I get this “no such extra feature” message
certbot --apache
UnknownExtra: requests 2.6.0 has no such extra feature ‘security’
Yeah… I’m floundering here.
shafer
August 2, 2017, 2:07pm
#7
Screw it. Using certbot-auto like you said.
shafer
August 2, 2017, 3:25pm
#8
That worked. Nothing to see here. Moving along.
system
closed
September 1, 2017, 3:26pm
#9
