Impossible to renew certificate - Please Help
Hello :slight_smile:
My certificate expires in 10 days and I can't renew it despite hours spent on internet to find the answer... I really need your help.
My domain is: candydates.be
I ran this command: sudo certbot renew --cert-name candydates.be -a webroot -w /var/www/letsencrypt --dry-run
Processing /etc/letsencrypt/renewal/candydates.be.conf
http-01 challenge for www.candydates.be
http-01 challenge for candydates.be
Using the webroot path /var/www/letsencrypt for all unmatched domains.
Challenge failed for domain www.candydates.be
Attempting to renew cert (candydates.be) from /etc/letsencrypt/renewal/candydates.be.conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/candydates.be/fullchain.pem (failure)
My web server is (include version): nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04.2 LTS
My hosting provider, if applicable, is: ovh for vps + infomaniak for domain name
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
Here is my /etc/nginx/site-available/candydates.conf file:
        listen [::]:80;
        listen 80;
        server_name candydates.be wwww.candydates.be;
                return 301 https://$server_name$request_uri;
                try_files $uri =404;
                root /var/www/letsencrypt;
server{
        listen 443 ssl http2 default_server;
        listen [::]:443 ssl http2 default_server;
        root /var/www/candydates/html;
        server_name candydates.be www.candydates.be;
        expires $expires;
        include snippets/ssl-candydates.be.conf;
        include snippets/ssl-params.conf;
                try_files $uri $uri/ /index.html;
                client_max_body_size 2050m;
                proxy_request_buffering off;
        location ~ /.well-known {
                allow all;
I don't have a lot of experience but I will do my best to give you as much information as I can to make it works.
Elodie
Hi @elo-bau, and welcome to the LE community forum :slight_smile:
This path:
does seem to match this path:
and this HTTP failure:
implies HTTPS redirection wasn't applied.
Which leaves me right where you are... :confused:
Let's confirm that path by creating a test text file in that expected challenge location and see if it can be accessed from the Internet.
Like:
echo "test file" > /var/www/letsencrypt/test-file-1234
then try:
http://candydates.be/.well-known/acme-challenge/test-file-1234
Also, please show this file:
and maybe also the output of this:
nginx -T | grep -Ei 'server_name|listen|well-known|root'
Hi @rg305,
Thanks you for your answer !
Here is my file /etc/letsencrypt/renewal/candydates.be.conf:
renew_before_expiry = 30 days
version = 0.40.0
archive_dir = /etc/letsencrypt/archive/candydates.be
cert = /etc/letsencrypt/live/candydates.be/cert.pem
privkey = /etc/letsencrypt/live/candydates.be/privkey.pem
chain = /etc/letsencrypt/live/candydates.be/chain.pem
fullchain = /etc/letsencrypt/live/candydates.be/fullchain.pem
[renewalparams]
account = fe8cfce83fca4646b394003f35aea8c0
authenticator = webroot
webroot_path = /var/www/candydates/html,
[[webroot_map]]
candydates.be = /var/www/candydates/html
www.candydates.be = /var/www/candydates/html
Here is the output of nginx -T | grep -Ei 'server_name|listen|well-known|root':
        server_names_hash_bucket_size 64;
#               listen     localhost:110;
#               listen     localhost:143;
  #listen       80;
  #listen       443 ssl;
  #server_name  localhost;
    listen [::]:80;
    listen 80;
    server_name api.candydates.be;
    #listen 443 ssl http2 default_server;
    listen 443 ssl http2;
    #listen [::]:443 ssl http2 default_server; # does not work properly with Angular, TODO research about this
    listen [::]:443 ssl http2;
    location /.well-known/{
        listen [::]:80;
        listen 80;
       #root /var/www/candydates/html;
        #       return 301 https://$server_name$request_uri;
        listen 80 default_server;
        root /var/www/html;
        server_name _;
#       listen 80;
#       listen [::]:80;
#       server_name example.com;
#       root /var/www/example.com;
I made the file and tried to reach http://candydates.be/.well-known/acme-challenge/test-file-1234 but I was redirected to https://candydates.be/.well-known/acme-challenge/test-file-1234. On the screen, I could see this:
AHA!!!!
[find the TYPO and win a prize!]
[I too overlooked it the first time it was presented]
Four w's?
We have a winner!
HTTP request was to 3 w's:
HTTP server listening to 4 w's:
Thank you so much @rg305 and @Osiris !!! It is always good to have a new vision on our code when we can't find a solution. :smiley:
