My domain is: wallet.myhush.org
I ran this command: sudo ./letsencrypt-auto renew
2019-07-08 00:26:03,553:DEBUG:certbot.main:certbot version: 0.35.1
2019-07-08 00:26:03,867:INFO:certbot.main:Renewing an existing certificate
2019-07-08 00:26:04,044:DEBUG:certbot.crypto_util:Generating key (2048 bits): /etc/letsencrypt/keys/0063_key-certbot.pem
2019-07-08 00:26:04,213:DEBUG:acme.client:JWS payload:
"identifiers": [
"type": "dns",
"value": "wallet.myhush.org"
2019-07-08 00:26:04,216:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
Expires: Sun, 07 Jul 2019 22:26:04 GMT
"type": "tls-alpn-01",
"status": "invalid",
"url": "https://acme-v02.api.letsencrypt.org/acme/challenge/5gGZZW6h71ATUWZSPnnv0GelPEnUnVYpITLIGpLM7Q8/17989604645",
"token": "nyO6MRZQkVEm0TWhDEERHDFqL0Sz6W5Jbj5ACbz0EpA"
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "Invalid response from http://wallet.myhush.org/.well-known/acme-challenge/DK4P54Sb7RhLiCaJM_w_DGfPdVqYjV5Llir5otCh0Qg [2606:4700:30::681f:5d71]: "\u003chtml\u003e\n\u003chead\u003e\u003ctitle\u003e404 Not Found\u003c/title\u003e\u003c/head\u003e\n\u003cbody bgcolor=\"white\"\u003e\n\u003ccenter\u003e\u003ch1\u003e404 Not Found\u003c/h1\u003e\u003c/center\u003e\n\u003chr\u003e\u003ccenter\u003engin"",
"status": 403
"url": "https://acme-v02.api.letsencrypt.org/acme/challenge/5gGZZW6h71ATUWZSPnnv0GelPEnUnVYpITLIGpLM7Q8/17989604646",
"token": "DK4P54Sb7RhLiCaJM_w_DGfPdVqYjV5Llir5otCh0Qg",
"validationRecord": [
"url": "http://wallet.myhush.org/.well-known/acme-challenge/DK4P54Sb7RhLiCaJM_w_DGfPdVqYjV5Llir5otCh0Qg",
"hostname": "wallet.myhush.org",
"port": "80",
"addressesResolved": [
"104.31.92.113",
"104.31.93.113",
> "2606:4700:30::681f:5d71",
> "2606:4700:30::681f:5c71"
"addressUsed": "2606:4700:30::681f:5d71"
2019-07-08 00:26:05,991:DEBUG:acme.client:Storing nonce: Sj1Vvy2ViKEsOsadO1kuhOUxwVNFhL1HI2Ctejnp7Rc
2019-07-08 00:26:05,991:WARNING:certbot.auth_handler:Challenge failed for domain wallet.myhush.org
2019-07-08 00:26:05,991:INFO:certbot.auth_handler:http-01 challenge for wallet.myhush.org
2019-07-08 00:26:05,992:DEBUG:certbot.reporter:Reporting to user: The following errors were reported by the server:Domain: wallet.myhush.org
Detail: Invalid response from http://wallet.myhush.org/.well-known/acme-challenge/DK4P54Sb7RhLiCaJM_w_DGfPdVqYjV5Llir5otCh0Qg [2606:4700:30::681f:5d71]: "\n404 Not Found\n<body bgcolor="white">\n404 Not Found
\n
ngin"To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address.
2019-07-08 00:26:05,992:DEBUG:certbot.error_handler:Encountered exception:
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 90, in handle_authorizations
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 154, in _poll_authorizations
AuthorizationError: Some challenges have failed.2019-07-08 00:26:05,992:DEBUG:certbot.error_handler:Calling registered functions
2019-07-08 00:26:05,992:INFO:certbot.auth_handler:Cleaning up challenges
2019-07-08 00:26:05,992:DEBUG:certbot.plugins.webroot:Removing /tmp/.well-known/acme-challenge/DK4P54Sb7RhLiCaJM_w_DGfPdVqYjV5Llir5otCh0Qg
2019-07-08 00:26:05,993:DEBUG:certbot.plugins.webroot:All challenges cleaned up
2019-07-08 00:26:05,993:WARNING:certbot.renewal:Attempting to renew cert (wallet.myhush.org) from /etc/letsencrypt/renewal/wallet.myhush.org.conf produced an unexpected error: Some challenges have failed.. Skipping.
AuthorizationError: Some challenges have failed.2019-07-08 00:26:05,994:ERROR:certbot.renewal:All renewal attempts failed. The following certs could not be renewed:
2019-07-08 00:26:05,994:ERROR:certbot.renewal: /etc/letsencrypt/live/wallet.myhush.org/fullchain.pem (failure)
Error: 1 renew failure(s), 0 parse failure(s)
My web server is (include version): nginx/1.14.0
My hosting provider, if applicable, is: contabo
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.35.1
I tried a lot of research but I could not find the solution.
I can not renew my certificate that ends today.
I created a file in the 'acme-challenge' folder at this address:
https://wallet.myhush.org/.well-known/acme-challenge/123456789
It is easily accessible from a browser.
I have the impression that there is an automatic redirection http -> https that blocks the renewal.
Here is some of my config nginx :
listen 80;
listen [::]:80;server_name wallet.myhush.org;
root /var/www/wallet.myhush.org;
index index.html;#include NGINXConfig | DigitalOcean;
allow all;
}location / {
return 301 https://wallet.myhush.org$request_uri;
access_log /var/log/nginx/myhushwallet80.access.log;
error_log /var/log/nginx/myhushwallet80.error.log;
Could you give me a track to fix this malfunction?
Best regards
gilardh
