Impossible to make HTTPS work
My domain is: forestak.com
My web server is (include version): ispconfig
The operating system my web server runs on is (include version): debian 10
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): ispconfig
Hello,
I need help to make https work.
My son create an Prestashop web site hosted on my web server where others https sites work perfectly. (and worked without any kind of problems)
When on ispconfig I clic on “Rewrite HTTP to HTTPS” the site become unaccessible.
If I don’t clic this option https is nor activated.
I contact my registrar “gandi.net” they said that the problem is a loop of redirections.
I try to make it work for more than 2 weeks but no results.
Please help
Many thanks
Janfi
Hi @Janfi
checking your domain via https://check-your-website.server-daten.de/?q=forestak.com - there
is no loop. There is a wrong redirect https -> http:
• http://www.forestak.com/ 116.203.202.203 302 http://forestak.com/ 0.064 D
• http://forestak.com/ 116.203.202.203 GZip used - 12095 / 63497 - 80,95 % 200 Html is minified: 149,99 % 1.070 H
• https://forestak.com/ 116.203.202.203 302 http://forestak.com/ 4.240 F
• https://www.forestak.com/ 116.203.202.203 302 http://forestak.com/ 3.450 F
but no redirect http -> https, so it's not a loop.
Remove that wrong redirect https -> http, then recheck your domain to see, if that redirect is gone.
Then create a redirect http -> https. Don't create that redirect first, that would create a loop.
Hello @JuergenAuer
Thank you very much for your answer.
Yesterday I did unclick on “Rewrite HTTP to HTTPS” because my son wanted to work on his site.
it is re-clicked now, and as you can see, the site is unaccessible.
I did clic on your link but I don’t have the knowledge to understand the problem.
Jean-Philippe
That's expected. You have to find your wrong redirect https -> http and remove it.
Please read some basics:
Yes but where to search ? I use ispconfig and normally, everything should work automaticaly, for others sites i had no problem.
I do not have big knowledge on web backgrounds.
I don't know, it's your configuration.
A redirect https -> http is untypical. May be your application or an old .htaccess
Hello,
Finally, yesterday night I could make it work, the problem was that the https must be activated in the backoffice of PrestaShop.
I still have a problem, when I clic on the small logo at the left of the url, it says that my connection is not fully secure, attackers can see images etc…
Is there any tool to report what exactly has to be changed to be fully secure ?
Thanks
Re-scan that url with "check-your-website", there is a content check included.
Thank you very much Juergen
