I'm getting an error message when generating Let'sEncrypt certificate from cloudpanel, my domain is successfully pointed to my vps machine, and I can access my home page, this is the error I'm getting:
docteur-aoun.com: Domain could not be validated, error message: error type: urn:ietf:params:acme:error:unauthorized, error detail: 2a02:4780:1e:5dba:5445:1ad5:c6ea:64ef: Invalid response from http://docteur-aoun.com/.well-known/acme-challenge/uf9igZI7nzgqGbcpw2wmCcYg5gq3qGp9Uvfee67PKeQ: 404
and
www.docteur-aoun.com: Domain could not be validated, error message: error type: urn:ietf:params:acme:error:unauthorized, error detail: 2a02:4780:21:3d3:9d62:a26:a59e:9482: Invalid response from http://www.docteur-aoun.com/.well-known/acme-challenge/Wfua2cqSrviqxrq66FKUcfWCQagt9noEcfnmlWmBs5U: 404
My server is running: nginx
My domain is: docteur-aoun.com
PHP version: 7.4
Mysql: Ver 8.0.35-0ubuntu0.22.04.1 for Linux on x86_64 ((Ubuntu))
OS: Ubuntu 22.04
My vhost:
listen 80;
listen [::]:80;
listen 443 ssl http2;
listen [::]:443 ssl http2;
{{ssl_certificate_key}}
{{ssl_certificate}}
server_name www.docteur-aoun.com;
return 301 https://docteur-aoun.com$request_uri;
listen 80;
listen [::]:80;
{{ssl_certificate}}
server_name docteur-aoun.com www1.docteur-aoun.com;
root /home/docteur-aoun/htdocs/docteur-aoun.com/public_html;
{{nginx_access_log}}
{{nginx_error_log}}
if ($scheme != "https") {
rewrite ^ https://$host$uri permanent;
location ~ /.well-known {
auth_basic off;
allow all;
{{settings}}
{{varnish_proxy_pass}}
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-Host $http_host;
proxy_hide_header X-Varnish;
proxy_redirect off;
proxy_max_temp_file_size 0;
proxy_connect_timeout 720;
proxy_send_timeout 720;
proxy_read_timeout 720;
proxy_buffer_size 128k;
proxy_buffers 4 256k;
proxy_busy_buffers_size 256k;
proxy_temp_file_write_size 256k;
location ~* ^.+\.(css|js|jpg|jpeg|gif|png|ico|gz|svg|svgz|ttf|otf|woff|woff2|eot|mp4|ogg|ogv|webm|webp|zip|swf|map)$ {
add_header Access-Control-Allow-Origin "*";
expires max;
access_log off;
if (-f $request_filename) {
break;
listen 8080;
listen [::]:8080;
try_files $uri $uri/ /index.php?$args;
index index.php index.html;
location ~ \.php$ {
include fastcgi_params;
fastcgi_intercept_errors on;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
try_files $uri =404;
fastcgi_read_timeout 3600;
fastcgi_send_timeout 3600;
fastcgi_param HTTPS "on";
fastcgi_param SERVER_PORT 443;
fastcgi_pass 127.0.0.1:{{php_fpm_port}};
fastcgi_param PHP_VALUE "{{php_settings}}";
# Environment variables
fastcgi_param ROOT_DIR "C:\\xampp\\htdocs\\docteur-aoun.com";
fastcgi_param PROJECT_URL "http://localhost/docteur-aoun.com";
fastcgi_param VENDOR_AUTOLOAD "/home/docteur-aoun/htdocs/docteur-aoun.com/public_html/vendor/autoload.php";
fastcgi_param PHP_VALUE "display_errors=On";
location /healthy-kitchen/ {
rewrite ^/healthy-kitchen/p/([^/]+)/?$ /healthy-kitchen/single-post.php?permalink=$1 last;
location /videos/ {
rewrite ^/videos/watch/([^/]+)/?$ /videos/watch.php?permalink=$1 last;
try_files $uri $uri/ $uri.php?$args;
break;
map $sent_http_content_type $expires {
default +2d;
image/jpg +1M;
image/svg+xml 1M;
image/gif +1M;
image/jpeg +1M;
image/png +1M;
text/css +1M;
text/javascript +1M;
application/javascript +1M;
application/x-shockwave-flash +1M;
image/ico +1M;
image/x-icon +1M;
text/html +600s;
I spend 2 days tryng to figure this out, I would appreciate the help.
rg305
December 18, 2023, 9:53am
2
HI @mrabdennour , and welcome to the LE community forum
Why are those IPs not the same?
rg305
December 18, 2023, 9:54am
3
Why are both IPs not the same?
Addresses: 2a02:4780:1d:758:e1fa:1fc9:70e2:8745
191.101.104.1
Aliases: www.docteur-aoun.com
Addresses: 2a02:4780:21:d1e5:2c86:14ac:8ed0:6e4a
85.31.237.200
This domain has been pointed to my vps, it is originally hosted on hostinger
rg305
December 18, 2023, 9:56am
5
It seems the IPs are still pointing to Hostinger CDN.
rg305
December 18, 2023, 9:58am
6
Doing HTTP and HTTPS in the same VHOST is bad practice.
Try splitting them in two separate VHOSTs.
rg305
December 18, 2023, 10:01am
7
Why have two different ways to redirect to HTTPS?:
The second way makes sense.
The first will redirect to HTTPS, even though it is listening to HTTPS!:
If that redirection "works", it creates an endless redirection loop.
I updated my dns records, now it's pointing to vps 100%, but I still get this error:
docteur-aoun.com: Domain could not be validated, error message: error type: urn:ietf:params:acme:error:unauthorized, error detail: 2a02:4780:22:5bf:bdb0:9917:844f:ff59: Invalid response from http://docteur-aoun.com/.well-known/acme-challenge/QAjBotEQ6F_vnLn0AdX3x42Xho791tqCkuWUDyo88S8: 404
I also updated my vhost:
listen 80;
listen [::]:80;
{{ssl_certificate}}
server_name docteur-aoun.com www.docteur-aoun.com;
{{nginx_error_log}}
auth_basic off;
allow all;
{{settings}}
proxy_redirect off;
expires max;
access_log off;
break;
listen 8080;
listen [::]:8080;
location ~ \.php$ {
location /videos/ {
break;
default +2d;
image/jpg +1M;
image/svg+xml 1M;
image/gif +1M;
image/jpeg +1M;
image/png +1M;
text/css +1M;
image/ico +1M;
image/x-icon +1M;
text/html +600s;
Even though I updated the vhost still getting same error
rg305
December 18, 2023, 4:15pm
11
Now this part is incomplete - it has no root.
I see no way for it to handle the HTTP ACME challenge requests.
[and it is only serving one of the two names you are requesting]
rg305
December 18, 2023, 4:18pm
12
Only the IPs for one of the names was changed/removed:
Addresses: 2a02:4780:27:1068:0:322e:6f2f:3
85.31.237.200
Address: 85.31.237.200
The error message clearly shows the name that is having the problem has similar IPs as before:
system
Closed
January 17, 2024, 4:19pm
13
