Domain could not be validated with ssl let's encrypt
I have this problem whenever I try to install let's encrypt:
docteur-aoun.com: Domain could not be validated, error message: error type: urn:ietf:params:acme:error:unauthorized, error detail: 2a02:4780:27:1068:0:322e:6f2f:3: Invalid response from http://docteur-aoun.com/.well-known/acme-challenge/nn8xgAgrf94mzIaa9pYtDYAxs1uiCz1U_dV1S-QIfpg: 404
My VPS features:
My server is running: nginx
My domain is: docteur-aoun.com
PHP version: 7.4
OS: Ubuntu 22.04
This is nslookup of the domain:
# nslookup docteur-aoun.com
Server:         127.0.0.53
Address:        127.0.0.53#53
Non-authoritative answer:
Address: 85.31.237.200
Address: 2a02:4780:27:1068:0:322e:6f2f:3
And this is my vhost:
  listen 80;
  listen [::]:80;
  server_name docteur-aoun.com www.docteur-aoun.com;
  root /home/docteur-aoun/htdocs/docteur-aoun.com/public_html;
  #skip challenge requests and
  location ^/(?!\.well-known) {
    #send all other requests to HTTPS
  }#location
  auth_basic off;
  allow all;
Open a shell on your vps and check if that IP address is the right one:
curl -6 ifconfig.co
I ran the command and this is the results:
2a02:4780:28:e1f::1
You should replace the contents of your AAAA record with that. (And check if that works. IPv6 can work in different ways.)
If that fails, speak with your IPv6 provider.
Maybe they can explain how they "make it work".
I mean, as an intermediate option, iproute2 should know.
Itried that, now I get this:
docteur-aoun.com: Domain could not be validated, error message: error type: urn:ietf:params:acme:error:unauthorized, error detail: 2a02:4780:28:e1f::1: Invalid response from http://docteur-aoun.com/.well-known/acme-challenge/oRpqsNRPX8JfRwR9gsSehMw481bK-GpeI8X57cUobn4: 404
What command are you using to request the cert?
Let's check/test the expected challenge location:
  • create the path:
    mkdir -p /home/docteur-aoun/htdocs/docteur-aoun.com/public_html/.well-known/acme-challenge/
  • place a sample test file in the expected challenge location:
    echo "testing" > /home/docteur-aoun/htdocs/docteur-aoun.com/public_html/.well-known/acme-challenge/Test_File-1234
  • verify access to the test file:
    curl -4 http://docteur-aoun.com/.well-known/acme-challenge/Test_File-1234
    curl -6 http://docteur-aoun.com/.well-known/acme-challenge/Test_File-1234
I did not mention this before, but I am using cloudpanel to install let's encrypt ssl
hmm...
Are there any other names that could conflict with this one?
Are there any using a wildcard?
I don't think the nginx server block above is the one being used. It should redirect non-ACME requests to HTTPS but instead I get a 403
curl -I4 http://docteur-aoun.com
HTTP/1.1 403 Forbidden
Server: nginx
What other devices are between your nginx server and the internet? A router? A firewall device?
I do have a subdomains
I am using a VPS server
Try running the same curl command, use 4 instead of 6 and tell us what happens.
I have those 2 records in my dns zone editor in hostinger:
Those are fine.
What could be the cause for failed validations, because I have another domain before this one and has been validated smoothly without any issues what so ever.
I would check if your IPv4 is the right one:
curl -4 ifconfig.co
I get this IP: 85.31.237.200
which is the correct ip for my VPS
