I unable to renew my expired certificate, please help me out
Hi Team,
sudo certbot --apache -d fankick.io
and
sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/fankick.io.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
http-01 challenge for fankick.io
Waiting for verification…
Attempting to renew cert (fankick.io) from /etc/letsencrypt/renewal/fankick.io.conf produced an unexpected error: Failed authorization procedure. fankick.io (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.fankick.io [13.126.107.219]: "<!doctype html><html lang=“en”><meta charset=“utf-8”><meta name=“HandheldFriendly” content=“true”/><meta name=“theme-color”. Skipping.
The following certs could not be renewed:
/etc/letsencrypt/live/fankick.io/fullchain.pem (failure)
The following certs were successfully renewed:
/etc/letsencrypt/live/www.fankick.io/fullchain.pem (success)
    Domain: fankick.io
    Detail: Invalid response from http://www.fankick.io
Server version: Apache/2.4.18 (Ubuntu)
Server built: 2018-04-18T14:53:04
Ubuntu
NameCheap
Yes
No
certbot 0.21.1
Here is my fankick.io conf file
renew_before_expiry = 30 days
version = 0.21.1
archive_dir = /etc/letsencrypt/archive/fankick.io
cert = /etc/letsencrypt/live/fankick.io/cert.pem
privkey = /etc/letsencrypt/live/fankick.io/privkey.pem
chain = /etc/letsencrypt/live/fankick.io/chain.pem
fullchain = /etc/letsencrypt/live/fankick.io/fullchain.pem
[renewalparams]
authenticator = apache
installer = apache
account = XXXXXXXXXXXXXXXXXXXXXXX
Hi @Narendar22
looks like your configuration can't work.
You have two different ip addresses ( https://check-your-website.server-daten.de/?q=fankick.io ):
fankick.io A 162.255.119.65 yes 1 0
AAAA yes
www.fankick.io C ec2-13-126-107-219.ap-south-1.compute.amazonaws.com yes 1 0
A 13.126.107.219 yes
Your www is hosted via amazon.
But your redirects:
• http://fankick.io/
162.255.119.65 302 http://www.fankick.io 0.370 D
• http://www.fankick.io 200 0.260 H
• http://www.fankick.io/
13.126.107.219 200 0.257 H
• https://fankick.io/
162.255.119.65 -2 1.554 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 162.255.119.65:443
• https://www.fankick.io/
13.126.107.219 200 1.533 B
• http://fankick.io/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
162.255.119.65 302 http://www.fankick.io 0.374 D
Visible Content: Found .
• http://www.fankick.io/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
Visible Content: You need to enable JavaScript to run this app.
Using http-01 validation Certbot creates a file in /.well-known/acme-challenge, Letsencrypt checks that file.
But your http + non-www + /.well-known/acme-challenge is redirected to your http + www version.
Which ip address use your Certbot? If Certbot uses the 162.* address, Certbot can't create a file on 13.*.
Hii @JuergenAuer
Thanks for responding!
I am using Certbot on 13.126.107.219 IP.
Can you please help me on configuration.
There answers an application, not your webserver.
You should create something like an exception, so your webserver handles that request, not your app.
