Issues with renewing certbot certificate - urn:acme:error:unauthorized :: The client lacks sufficient authorization
My domain is: www.hiptraveler.com
I ran this command: sudo certbot renew --dry-run to test renewal of certificate
http-01 challenge for www.hiptraveler.com
http-01 challenge for turistavip.hiptraveler.com
Waiting for verification…
Attempting to renew cert (www.hiptraveler.com) from /etc/letsencrypt/renewal/www.hiptraveler.com.conf produced an unexpected error: Failed authorization procedure. www.hiptraveler.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.hiptraveler.com/.well-known/acme-challenge/dXz_xT7pFoplozYQlSOF0j1wDfZM9jqG4yHHe8NIato: “Apache Tomcat/7.0.52 (Ubuntu) - Error report<!–H1 {font-family:Tahoma,Arial,sans-serif;color:”. Skipping.
/etc/letsencrypt/live/www.hiptraveler.com/fullchain.pem (failure)
My web server is (include version): Apache/2.4.7 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 14.04
Yes, I can login to a root shell on my machine
No, I’m not using a control panel to manage my site.
Note - I received an email from LetsEncrypt on May 17, 2018 that certificate for domain www.hiptraveler.com was expiring in 10 days (which was correct according to my calculation as well) but when I run command -
sudo certbot certificates, it shows me the following output -
Found the following certs:
Certificate Name: www.hiptraveler.com
Domains: www.hiptraveler.com turistavip.hiptraveler.com
Expiry Date: 2018-07-28 23:33:13+00:00 (VALID: 65 days)
Can You please check the validity of our certificate and tell me when it really is expiring? Cos if it is expiring on May 28th, 2018 as mentioned in the email, then I need to really resolve this issue as soon as possible.
Thank you so much!
Swati
The current cert in use will expire in 2 months and 4 days:
https://www.ssllabs.com/ssltest/analyze.html?d=www.hiptraveler.com
The email notification is about a previously issued cert that will be expiring soon:
https://crt.sh/?q=www.hiptraveler.com
You can always check the validity of your currently installed (in use) cert with:
