I need to upgrade from certbot-auto
I did:
sudo apt-get remove certbot
sudo snap install --classic certbot
sudo ln -s /snap/bin/certbot /usr/bin/certbot
sudo certbot renew --dry-run -d bc.elmit.com
Currently, the renew verb is capable of either renewing all installed certificates that are due to be renewed or renewing a single certificate specified by its name. If you would like to renew specific certificates by their domains, use the certonly command instead. The renew verb may provide other options for selecting certificates to renew in the future.
My domain is: bc.elmit.com
sudo certbot --certonly --rsa-key-size 4096 --nginx --agree-tos --no-eff-email --email ronald@example.com -w /home/ronald/docker-websites/bc.elmit.com -d bc.elmit.com
nginx -v
nginx version: nginx/1.14.0 (Ubuntu)
lsb_release
LSB Version: core-9.20170808ubuntu1-noarch:printing-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch
yes, sudo
How can I fix it?
Your current issues don't look related to the way you've installed certbot: certbot seems to be working fine.
However, for some reason you're trying to use the renew subcommand with options not related to that subcommand.
Doesn't certbot renew --dry-run without any other options just work?
Also, you can check which certificates are installed including their certificate name with the command certbot certificates, so you can specifically renew certificates with the --cert-name option in combination with certbot renew.
Thanks for your quick reply.
I tried sudo certbot renew --dry-run
which returned a lots of errors for each domain I have:
Processing /etc/letsencrypt/renewal/ai.elmit.com.conf
Error while running nginx -c /etc/nginx/nginx.conf -t.
nginx: [emerg] BIO_new_file("/etc/letsencrypt/live/nc.elmit.com/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/nc.elmit.com/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
nginx: configuration file /etc/nginx/nginx.conf test failed
Failed to renew certificate ai.elmit.com with error: The nginx plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError('Error while running nginx -c /etc/nginx/nginx.conf -t.\n\nnginx: [emerg] BIO_new_file("/etc/letsencrypt/live/nc.elmit.com/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/nc.elmit.com/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)\nnginx: configuration file /etc/nginx/nginx.conf test failed\n')
Your suggestion to use:
sudo certbot certificates
Renewal configuration file /etc/letsencrypt/renewal/www.elmit.com.conf produced an unexpected error: renewal config file {} is missing a required file reference. Skipping.
Found the following certs:
Certificate Name: ai.elmit.com
Serial Number: 3a0dc19d1f8a17c5bbe09e708451ec3d4c2
Key Type: RSA
Domains: ai.elmit.com
Expiry Date: 2021-10-16 22:51:32+00:00 (VALID: 16 hour(s))
Certificate Path: /etc/letsencrypt/live/ai.elmit.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/ai.elmit.com/privkey.pem
... was good
I tried then:
sudo certbot renew --cert-name bc.elmit.com
Processing /etc/letsencrypt/renewal/bc.elmit.com.conf
Failed to renew certificate bc.elmit.com with error: The nginx plugin is not working; there may be problems with your existing configuration.
/etc/letsencrypt/live/bc.elmit.com/fullchain.pem (failure)
sudo nginx -t
This is kinda a weird error. Can you show the contents of the file /etc/letsencrypt/renewal/www.elmit.com.conf please?
It seems certbot does not know the certificate name bc.elmit.com. At least, I can't see it in the output of certbot certificates or was there more output on your screen which wasn't copy/pasted into your post?
Your nginx configuration is refering to a certificate called nc.elmit.com but that certificate isn't there any longer, so nginx is malfunctioning: it expects to find a certificate, but it's gone! Did you perhaps remove certain certificates from certbot without removing them from your nginx configuration? Please see the warnings and solution(s) about safely deleting certificates in certbot here: User Guide — Certbot 2.7.0.dev0 documentation
I checked the file www.elmit.com.conf - it is an empty file. Since I do not currently use this domain. I deleted the empty file.
That helped that the command sudo certbot renew
Another instance of Certbot is already running.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/tmpy2sawccz/log or re-run Certbot with -v for more details.
sudo certbot renew -v
Certificate is due for renewal, auto-renewing...
cat bc.elmit.com.conf
renew_before_expiry = 30 days
version = 1.9.0
archive_dir = /etc/letsencrypt/archive/bc.elmit.com
cert = /etc/letsencrypt/live/bc.elmit.com/cert.pem
privkey = /etc/letsencrypt/live/bc.elmit.com/privkey.pem
chain = /etc/letsencrypt/live/bc.elmit.com/chain.pem
fullchain = /etc/letsencrypt/live/bc.elmit.com/fullchain.pem
[renewalparams]
authenticator = nginx
installer = nginx
account = 847eabe6723b218efd22650696b29796
rsa_key_size = 4096
First, and foremost, your nginx configuration needs to work.
[as long as nginx -t fails, nothing else will work (certbot can't fix that for you)]
You may need to disable whatever files are missing (or recreate them) to get nginx working.
Thanks. For now I fixed the config files. Will come next week with the remaining problem to solve.
Thanks.
